  #31 (permalink)
Old December 18, 2009, 07:03 PM
MarkOne's Avatar
since I don't overclock the I7, I will try this cpu cooler, so I will not have to remove the motherboard, the review are not bad at all
Hyper TX3 - Cooler Master
  #32 (permalink)
Old December 18, 2009, 07:58 PM
martin_metal_88's Avatar
well it's a mini Hyper 212+ so it would perform pretty good but probably a little bit more noisy because it use 92mm fan.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #33 (permalink)
Old December 18, 2009, 08:49 PM
If you don't want to remove the motherboard, the Xigmatek HDT-S1283 would be a better choice.
  #34 (permalink)
Old December 18, 2009, 09:53 PM
Raserei408's Avatar
I disagree. I've got the Xigmatek, and it was a nightmare to install outside of the case. I don't even want to think how bad it would have been in a cramped case.
Also, why not remove the mobo? It's not that hard once you know where everything goes and, while it takes some time, you'll end up with a better cooler.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
  #35 (permalink)
Old December 18, 2009, 10:01 PM
I disagree. I've got the Xigmatek, and it took me about 10 seconds to install with my motherboard already mounted inside my case.
  #36 (permalink)
Old December 19, 2009, 02:44 AM
MarkOne's Avatar
Yes it's look a better cooler, but it's fit only on a 775 , but I will order it , today I remove my Q6600 water cooled from my Mozart, it will go in my Lancool , and I give it to my Dad, he only surf on the web and play solitaire. When I gone receive it I will just remove the stock cooler and place it
I look at the instruction, it doesn't look more hard to install than a stock cooler, you just push the pins
after 25 years of working in the field, I guess I know where the thing go , but removing the board is always a risk to damage something, I don't need the best cooler, it will not be OC, but after think about it, I doN't like vertical tower cooler, they don't cool the chipset and mosfet very well, so I will put the 1156 version of my trusty noctua c12p , this one make a realgood job and push air at the good place.
Noctua NH-C12P CPU Cooler Review
  #37 (permalink)
Old December 19, 2009, 09:20 AM
Exactly. I don't understand why people complain about the push-pin mounting system. It's extremely easy to use.
  #38 (permalink)
Ah yes, I forgot about that. There is an LGA1156 mounting kit, but I believe it requires a backplate.
  #39 (permalink)
Old December 19, 2009, 09:22 AM
Yup:) When you want a good cooler for a stock clock CPU, also a cooler the will probably never move from there pushpin are probably the best. Personally I use backplate only on my main rig because want my CPU to be tight and because I change it every 2 or 3 months so pushpin would broke with time.
Ask for more
Martin_metal_88
  #40 (permalink)
Old December 19, 2009, 09:25 AM
What I do miss is the old P4 mounting system. That was really well designed. But the push-pin system is more versatile, and also allows coolers to be mounted in any orientation since it's a square hole pattern.
Cooling GPU. Antec 300 case TMan Air Cooling 1 September 18, 2009 03:07 PM
Thermaltake ISGC V320 – The Latest Heavy Hitter In GPU Cooling Soultribunal Press Releases & Tech News 6 July 9, 2009 09:00 AM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
My 1st GPU cooling Mod, any advise? CasheKicker Air Cooling 12 February 14, 2009 04:26 PM
Arctic Cooling Launches Accelero TWIN TURBO GPU Cooler MAC Press Releases & Tech News 18 August 31, 2008 08:42 PM
