<~----> I7 860 Cooling and GPU - Page 3 - Hardware Canucks
  #21 (permalink)
Old December 18, 2009, 11:17 AM
martin_metal_88's Avatar
Mark you really do have to much money to spend. But that will be a killer rig! really hope to see where you can push it! I just done mine at 4.01 GHZ this morning. Looking for better cooling now to get further.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #22 (permalink)
Old December 18, 2009, 12:50 PM
MarkOne's Avatar
that's my question tonight in an other post, when I buy the i5 , Mike told me it push it to 4,2 with the 212+, when I get it it was a 4,0 : but I don't know if I gone put the I5 or the I7-860. this rig will be for gaming, I will keep the Lancool with the gigabyte ( someone told me they are more leliable than asus ) for my WS, I know I will better with the I7 for this, but I'm may be too lassy to remove the 212+ to change the CPU, I will see tonight. the question is, which is the best OC cpu the 750 or the 860 ?
Now if you look at the Mozart, it have 4 holes on the top at the back for 4 120 fan, it's where will go the quad rad, if I need I will cut the aluminium and make an other plate for the rad, if you look more you will see that you can put a secong mini-itx board , with a 7" touch screen, this will be use for control the OC true the rog connect.. It's 1 year I have this case and the ITX and don't know what to do with it..
Just imagine the rig, a touch screen build in the face of the case to play with the OC' and all the rad inside the case. I already have the accessory power supply of thermalrake for the mini-itx.
  #23 (permalink)
Old December 18, 2009, 12:57 PM
3oh6's Avatar
Hardware Canucks Reviewer
you can't say one CPU (i5 750 or i7 860) is a better overclocker because it is luck of the draw. some 750's will clock better than 860's and some 860's will clock better than 750's.
the biggest difference between the two is going to be the heat. 4 cores without HT runs a lot cooler than 4 cores with HT...AKA 750 without, and 860 with HT. of course, you can always turn the HT off on the 860.
  #24 (permalink)
Old December 18, 2009, 01:03 PM
MarkOne's Avatar
thanks 3oh6, I guess hyperis not a need for gaming..... so I'm better to keep my 860 for my WS , I will have to swap the CPU
I most add than I will not OC the one in the WS, so I'm better go with the 750 for OC, if he do bad , I can always buy an other one and use the one that clock less an other place.
And it's less hard on the wallet, to make a mistake with a 750
  #25 (permalink)
Old December 18, 2009, 01:05 PM
MarkOne's Avatar
I just check my order at PC perfoemance, they are quick , as usally, order this morning, already ship
12/18/2009Processing
PayPal status: Completed @ 08:57:14
Dec 18, 2009 PST12/18/2009Shipped
  #26 (permalink)
Old December 18, 2009, 01:15 PM
Originally Posted by MarkOne View Post
I change a little bit the build I Will put the parts in My mozart. for now I jusr order this, so it will give you an idea on the cooling
MagiCool XTREME QUAD 480 Radiator Products Model: MC-XTREME480 [MC-XTREME480] : Performance-PCs.com, ... sleeve it and they will come
will start a work log too
That radiator uses 1/4" fittings. It won't work very well with a typical high-flow watercooling setup. That diameter tubing is usually used by German-made WC hardware, but I don't know if it would perform up to par compared to a 1/2" or 3/4"-based loop.
  #27 (permalink)
Old December 18, 2009, 01:27 PM
Well mark if you put the 860 under the hyper 212 it will run pretty hot if you get it to 4.0Ghz. Mine is ( full load in linx ) between 77-80) at 1.36Vcore 1.22VTT. I think it`s pretty nice but now I want to add a second fan controller and a second fan on my proli. Keep us up to date my friend!
Ask for more
Martin_metal_88
  #28 (permalink)
Old December 18, 2009, 03:08 PM
MarkOne's Avatar
Martin, the 860 will not be OC, it's my WorkStation, and don't talk about the :censo red:
212+,
it's good thing I swap the CPU, the kid who have it before his very strong, he strip 1 screw of the 212+ and an other one is half strip, it was holding on 3 screw only , so no way I can reinstall the 212+ tonight, I put back an Intel cooler , it's realy p... me off I will have to remove again the motherboard to put a cooler, I already order a noctua, can find them only at NCIX, knowing them I'm in luck if I have it before my kid return to school the 5 of January, so I will get stock with the stock cooler for a wild.
ok I was here to download the firmware of the SSD, better go well
  #29 (permalink)
Old December 18, 2009, 03:54 PM
Well, you know what they say; if you want it done right, you have to do it yourself...
  #30 (permalink)
Old December 18, 2009, 05:26 PM
MarkOne's Avatar
ok I'm back. so here the status of the build
Antec 1200
ep55-ud3r
I7-860 ( with stock cooler)
4 Gb of ram will bring this to 8
Windows 7 pro on Intel X25-m
2 x 500 black no raid
HD 4890
Plextor DVDR lightscrib
tomorow I will put the parts inside the Mozart in the Lancool, and with start my worklog on the build
Not to bad the SSD, I use only one, I will order an other one to make the raid in the Mozard
Cooling GPU. Antec 300 case TMan Air Cooling 1 September 18, 2009 03:07 PM
Thermaltake ISGC V320 – The Latest Heavy Hitter In GPU Cooling Soultribunal Press Releases & Tech News 6 July 9, 2009 09:00 AM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
My 1st GPU cooling Mod, any advise? CasheKicker Air Cooling 12 February 14, 2009 04:26 PM
Arctic Cooling Launches Accelero TWIN TURBO GPU Cooler MAC Press Releases & Tech News 18 August 31, 2008 08:42 PM
