Old December 16, 2009, 09:56 AM
manbearpig's Avatar
Default i5 system this month with a few questions
Greetings folks. I thought I had a good grasp on what I need to build a new PC but after some research I'm more confused than ever. Hopefully you all can set me straight. Thanks.
Gaming, office some photo editing but nothing heavy - daily use
2. What YOUR budget is.
$1100
Canada - Vancouver NCIX, Best Direct, Direct Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None
Probably go all new - I have a Thermaltake Tsunami case but figure I'd just throw together a whole new rig. See my sig I think it will be easier passing that machine onto a relative.
I've done a good amount of research so I'll keep this simple.
Probably not.
December - watching sales etc and looking for deals.
I am running a 20inch 1680x1050 monitor
Things I'm 98% on:
i5 750
cheapest DVD-RW drive at the time
640G WD Caviar Black
I'll pick a case based on price at the time. Anywhere from Gamma, Scout to HOF got a pretty decent grasp on what is good.
*OK I say 98% in case there's some crazy deal on an AMD PII X4 965 and board.
Things that really confuse me:
Video Card - Thinking 5770 with potential to Crossfire if I ever need more power -
so with that said what mobo?
Something in the $140-$170 range would be nice, any of these? Do they have the adequate PCI slots?
MSI P55-GD65
NCIX.com - Buy MSI P55-GD65 ATX LGA1156 P55 DDR3 3PCI-E16 CrossFire SLI 2PCI-E1 PCI-E4 2PCI eSATA GBLAN Motherboard - P55-GD65 In Canada.
ASUS P7P55D
NCIX.com - Buy ASUS P7P55D LGA1156 P55 DDR3 2PCI-E16 2PCI-E1 3PCI 7SATA CrossFire GBLAN 8CHANNEL Audio Motherboard - P7P55D In Canada.
GIGABYTE P55M-UD4
NCIX.com - Buy Gigabyte P55M-UD4 mATX LGA1156 P55 DDR3 2PCI-E 1PCI-E4 1PCI GLAN CrossFireX SLI Motherboard - GA-P55M-UD4 In Canada.
*Would a 4890 last me many more years and be that much better a power increase?
POWER:
NCIX has had supplies like this on for $80-90 are they enough if I want to crossfire one day? Or stick to the Corsairs like X750W etc?
NCIX.com - Buy Antec Earthwatts 750W Modular Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 135MM Fan - EA750 In Canada.
MEMORY: 4 gigs of something around $100
I hear Ripjaws around hear all the time. These ones?
Newegg.ca - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Desktop Memory
Thanks
AMD64 3700+ | Asus A8V | 2G OCZ Platinum | BFG 7800GS OC AGP | WD 80G | Enermax 460W | Thermaltake Tsunami
Yes my system is old
Old December 16, 2009, 05:36 PM
Helix's Avatar
Looks like a solid start.
In regards to the motherboard, if you're looking to Crossfire the Asus is straight out. The PCIe slots operate at X16/X4. When using multi-GPU's on a P55 motherboard, you need one that splits the lanes to be X8/X8.
The Gigabyte board and the MSI do not suffer from the same problem.
Old December 16, 2009, 06:11 PM
Fudd Rucker's Avatar
Im currently RMAing an Asus P7P55D and to replace it im using the GA -P55M -UD4 and the gigabyte board is hands down better board in my opinion.
I couldnt think of something snarky or interesting to put here this time around.
Old December 16, 2009, 06:38 PM
MarkOne's Avatar
if you give me choice only betwen those 3 one I will say the MSI, like Helix said the Asus is 16/4 and the giga is a mATX
Old December 16, 2009, 07:10 PM
MonsterSound's Avatar
You might consider the G.SKILL F3-10666CL7D-4GBRH Ripjaws PC3-10666 4GB 2X2GB DDR3-1333 CL7-7-7-21 Core I5 1.65V Memory Kit. I am using it and just setting XMProfile in the BIOS gets you 7,7,7,21 at 1600mhz fully stable. I haven't had time to play with it much but I have read others are getting over 2000 with decent timmings (if you are so inclined).
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / Windforce 7970 / MSI Z77A-G45 / 8gb G.Skill 2133 1T / ASUS 25.5" / Antec P280 / PCP&C 950 / Intel 520 SSD 2400gb / Eclipse / G3-Lazer / YSM1 / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old December 16, 2009, 07:12 PM
martin_metal_88's Avatar
Drop the P55M and pay 10$ more for the P55-UD4P??? this board will blow all other out. If you want to OC drop the ripjaws and get something better. Ho and 5770 will be fine:) and these card wont be bottlenecked by a 8X/8X PCI-e.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old December 16, 2009, 07:58 PM
MarkOne's Avatar
+1 with Martin for the ud4P
Old December 16, 2009, 08:10 PM
I was sure that mark would come back and aprove:)
Ask for more
Martin_metal_88
Old December 17, 2009, 02:11 PM
manbearpig's Avatar
So how much power do I need. I know different brands/watt-ages are better than others.
Also would a GTX 285 be worth it for $269 new?
Old December 17, 2009, 02:45 PM
The Corsair TX750 would probably be a good buy for you. More than enough power at a relatively low price.
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Let's see the most bandwidth usage in 1 month Myiagros Off Topic 42 November 1, 2009 01:11 AM
1st month of folding dhoshaw HardwareCanucks F@H Team 3 May 24, 2009 04:09 PM
[FS] Never used Swiftech WC gear less than a month old mhw100 Buy/Sell & Trade 13 April 3, 2009 03:57 PM
FS: Q9550 Used less than 1 month! Nademon Buy/Sell & Trade 12 October 20, 2008 09:35 PM
My new system and some questions Chrisahl CPU's and Motherboards 21 August 2, 2007 12:36 PM
