<~----> In Need of an Upgrade - Hardware Canucks
Old December 15, 2009, 07:19 PM
PC_Commando's Avatar
Default In Need of an Upgrade
Hi all, first time poster. The system I have, I had since 2005. I'll list the specs:
AMD Athlon XP 3200 Barton 2.2GHz
Asus A7V8X-X VIA KT400
Crucial 1GB PC2700 DDR333
Maxtor DiamondMax 20GB IDE
XFX GeForce 7900 GS AGP
LG 16x DVD±RW
SoundBlaster Live Value
Generic Beige Case
Generic 300W Power Supply
Gaming MW2 (The reason why I'm building the PC) and usual Office stuff, Graphics & Web Design and Internet Surfing.
$600.00 Max before MIR. This does not include a monitor but does include keyboard, mouse and speakers.
Preferably NCIX, Direct Canada or sister sites. (Canada Computers if necessary)
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I like AMD but if Intel provides a better deal, willing to go that route.
No old parts will be used
Yes I have, OCN, Hard OCP and here
Free Horsepower. Of course
Shortly after the new year, say Mid Jan to Early Feb, depending on funds.
The above information IS NEEDED, in order that WE can help YOU make wise judgments on YOUR purchases
Thank you all in advanced for your advice.
Old December 15, 2009, 07:42 PM
MonsterSound's Avatar
Just thought that I'd mention that if I was buying with your budget, I would consider the:
AMD Phenom II X2 550 Black Edition Dual Core Processor Socket AM3 3.1GHZ 7MB Cache for $110 at DirectCanada and try to unlock the other 2 cores with a decent AM3 MB (a good overclocker too). This CPU would leave more money for a decent video card.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old December 15, 2009, 09:02 PM
Raserei408's Avatar
If you do get that CPU, I'd recommend an ASUS board (M4A79XTD, or somethings similar) because recent BIOS allows you to pick which cores to reactivate. On this CPU it's very helpful, since it's not all or nothing. 1 core may be bad but the other three are fine, and you can activate all but the bad one. Just my advice.
Best way to go to upgrade. Bubbzilla Video Cards 17 August 11, 2009 05:14 PM
little upgrade BT! Case Mods, Worklog & Gallery 6 December 31, 2008 08:08 PM
Looking To Upgrade Scart New Builds 6 September 18, 2008 11:39 AM
Want to upgrade, but need some help. Mysteryous New Builds 2 August 6, 2008 03:05 PM
should I upgrade yycraven CPU's and Motherboards 13 December 10, 2007 05:10 PM
