Old December 9, 2009, 11:14 PM
Question First build, 1600$ budget, i7 860.. suggestion? would it work
Heavy computation programs like matlab, simulink + extensive gaming
1300 - 1600$
Canada, I think.. I am liking BestDirect.ca so far, I guess they are in Canada.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Big time Intel Fanboy, the other things I don't have a preference
Keyboard, probably a second monitor, speakers.
been researching for a while
default at first, don't mind overclocking if I feel like it's needed.
Soon ! in the holidays
I've put together this list, but I am not sure if it would work...
- CPU
Intel Core i7 860 Quad Core Processor Lynnfield LGA1156 2.8GHZ Hyperthreading 8MB Cache
- MOBO
Intel DP55KG Extreme Series ATX LGA1156 P55 DDR3 2PCI-E16 2PCI-E1 SLI Crossfire Motherboard
- Video card
Diamond Radeon HD 5870 850MHZ 1GB GDDR5 4.8GHZ 2XDVI HDMI Display Port DIRECTX11 PCI-E
- RAM
G.SKILL F3-10666CL9D-4GBNQ PC3-10666 4GB 2X2GB DDR3-1333 CL9-9-9-24 240PIN Dual Channel Memory Kit
- PSU
OCZ StealthXStream 700W ATX12V 20/24PIN Active PFC ATX Power Supply 120MM Fan Black
- Monitor
ASUS VH236H 23 Widescreen LCD Monitor Black 1920X1080 16:9 2MS 20000:1DC HDMI DVI VGA with Speakers
- DVD Writer
Samsung SH-S223L/BEBS 22X SATA Black DVD Writer Lightscribe OEM
- Keyboard
Logitech G11 Gaming Keyboard Black Silver Programmable Backlit Keys USB
- HDD
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
- Case
Compucase 6BRBBB Mid-Tower ATX Case Black 3X5.25 2X3.5 4X3.5INT No PS Front USB Audio eSATA
- Heat sink
Genius G950 Multi Socket Desktop CPU Cooler 4 Aluminum HeatPipes LGA1156 1366 775 AM3 AM2+ AM2
My reasoning for the 860 instead of the 920 is I want the fastest for computation hungry applications like matlab. For the Intel mobo is that 1. I like intel ! 2. I want maximum compatibility, 3. I like the bluetooth idea. the HD 5870, is it's great riviews and compared to the GTX ones, for its price it looks very good
What do you guys think ??
Thanks in advance !!! :)
Old December 10, 2009, 10:41 AM
I think you should spoil your new parts with a nicer case.
Old December 10, 2009, 12:24 PM
hmm.. I didn't put much thinking into the case..But now that you brought it up..
what do you think of this one ?
Antec Six Hundred Mid Tower Gaming Case 600 ATX 3X5.25 6X3.5INT 1 SATA Hot-Swap Bay No PS
Old December 10, 2009, 12:27 PM
misterd's Avatar
+1 to that. I've never used one of those cases, but for a couple more bucks & the same basic look and a better build I would get an Antec 300 Buy ANTEC [THREE HUNDRED] Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
Also this is a proven cooler + cheaper Buy COOLERMASTER [RR-B10-212P-GP] Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM
Have fun and good luck with your build.
Ask for more!
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old December 10, 2009, 12:28 PM
rapmaster's Avatar
That's ugly IMO, and in terms of cable management, it's bad.
Maybe something like those:
Buy COOLERMASTER [SGC-6000-KXN1-GP] Coolermaster Storm Sniper Black Edition Mid Tower ATX Case Black 5X5.25 5X3.5INT 1X2.5 No PSU
Buy COOLERMASTER [SGC-2000-KKN1-GP] Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU
Quando omni flunkus moritati
Old December 10, 2009, 12:31 PM
rapmaster's Avatar
Oh, and if it's possible, don't get the Diamond brand 5870, it has the worst customer service for ATI brand video cards, anything else would be better, especially XFX.
Old December 10, 2009, 01:37 PM
Thanks everyone for the input.. Here are the changes:
Case:Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU [thanks rapmaster]
Heat sink:Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM [Thanks misterd]
[edit] For the graphics card, I am thinking about this now, if you say the Diamond is bad..
SAPPHIRE 100282SR Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity - Retail This way would also save a 100$
i7 860 build Eldonko Case Mods, Worklog & Gallery 23 November 9, 2009 08:32 AM
my i7 860 Build Sandro_Bit New Builds 5 September 11, 2009 10:34 AM
New Build need your reactions and suggestion :D CORE New Builds 3 April 21, 2009 06:56 PM
suggestion for a intel build ebdoradz CPU's and Motherboards 9 February 13, 2008 09:43 AM
Another WC Suggestion Build Thread Supergrover Water Cooling 13 September 15, 2007 07:47 PM
