Old December 5, 2009, 09:53 AM
Default My first build O.o
1. What YOUR PC will be used for.
Gameing
2. What YOUR budget is.
£650
3. What country
UK
4. IF YOU have a brand preference.
AMD-Fanboy, ATI-Fanboy
None
yes...
For Xmas
Scythe Shuriken BIG Quiet Multi-Format CPU Cooler
OCZ 600W StealthXStream PSU, PowerWhisper, Active PFC
Asrock M3A790GXH/128M AM3,DDR3,7.1Snd,hCfire,ATX
250Gb Maxtor DiamondMax21 SATAI/II 8Mb Cache Hard Drive
OCZ Reaper 2Gb DDR3 1333MHz (2x1Gb) Dual Channel Kit
Asus 1024Mb ATi Radeon HD 5770 PCI-Express VGA Card
NZXT m59 Classic Series ATX Gaming Case
AMD Phenom II X4 965 Black Edition AM3 Processor
Total=£639.29 from Eclipse Computers
This is the build i want and i am ready to hit the buy button..and get stuck in with my first build
but i am not sure if its 100% compatible and if a 600watt PSU is good enough?
Old December 5, 2009, 01:53 PM
Raserei408's Avatar
Everything is compatible and would theoretically work. I do have several cautions, however. First, you're using a PII 965 but only 2GB of RAM, an average motherboard and a 250GB hard drive. Why? If you're mostly gaming then you should be investing in a better video card and more RAM, since the CPU is usually second-fiddle to the GPU when it comes to FPS.
I would drop to at least a 955 just to free up some of the budget, even down to a 720 if need be.
Where do you plan to buy your parts from? I'll see if I can put together a setup within your budget.
Old December 6, 2009, 01:00 AM
yep thats just what i was looking for thank you!
this is just a starter build i will be adding more RAM and a better GPU i just cant afford to spend anymore than 650 at the moment so a medicore GPU seemed to be the right way to go.
im buying from this site >>> Eclipse Computers
Old December 6, 2009, 07:22 PM
Raserei408's Avatar
Well, based on that site's prices and your budget, this is what I've come up with. Just my suggestions based on my experience, if there are problems don't flame me.
Total price is ~645.
Old December 7, 2009, 05:05 AM
OK that looks great thanks
but i have one question the (Corsair Twin3X 4Gb DDR3 1600 (2x2Gb) CAS9 DHX Kit) the Motherboard says 1666OC i have no idea about overclocking and that’s the reason why i was going to go for the 1333 ram in the first place.
do you suggest i look into OCing or just buy 4gb of 1333?
or do i have the completely wrong idea of OC?
(still very much new to this building stuff)
Old December 7, 2009, 05:10 AM
Raserei408's Avatar
As far as I can tell, the 1666 on the motherboard means that the board natively supports memory speeds up to 1666 (though by overclocking you can get memory to run faster). 1600 should run fine, and if it doesn't the RAM should get to 1666 easily enough. Small voltage increase and maybe loosening the timings should get you there easily enough.
Old December 7, 2009, 05:17 AM
alright thanks for all the help.
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
