Old November 19, 2009, 07:13 PM
Smile My First Build - Opinions Welcomed (Buying tomorrow)
Main computer. Gaming, internet surfing, little video editing, downloading 1080p videos ect.
Around $1 100
Canada, NCIX.com using shopbot.ca to find the best prices.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
N/A
DVD drive, mouse, Windows 7, monitor.
I looked at a few threads to see their format. My friend helped me create this list.
Overclocking if possible.
I plan on purchasing all the parts on Cyber Monday. (November 30th)
$289.00 MSI Radeon HD 5850 725MHZ 1GB GDDR5 4.0GHZ 2XDVI HDMI Display Port DIRECTX11 PCI-E Video Card
$204.97 Intel Core i5 750 Quad Core Processor Lynnfield LGA1156 2.66GHZ 8MB Cache Retail Box
$154.20 EVGA P55 LE ATX LGA1156 DDR3 CrossFire 2PCI-E16 1PCI-E1 3PCI Sound GBLAN Motherboard
$104.97 Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
$83.99 G.SKILL F3-12800CL7D-4GBRM Ripjaws 4GB 2X2GB DDR3-1600 CL7-8-7-24 240PIN Dual Channel i5 Memory Kit
$79.99 Coolermaster Haf 922 Mid Tower ATX Case Black 5X5.25 5X3.5INT Front Audio USB eSATA No PSU
$79.99 Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan *IR-$43*
$75.48 Razer Lycosa Gaming Ultrapolling Keyboard Black USB Programmable Blue Backlight NON-SLIP Keys
Shipping & Handling: $43.75
Shipping Insurance: $16.82
Subtotal: $1,182.19
GST(5%): $59.11
YOUR TOTAL: $1, 219.3
(Hopefully cheaper on Cyber Monday (Nov 30)
Thanks for reading.
Old November 19, 2009, 07:42 PM
stoanee's Avatar
Umm....it is long past Oct 27. Other than that it looks good. You will need an aftermarket cpu cooler if you overclock.
heatware
Old November 19, 2009, 07:48 PM
Doh, I meant November, lol. Updated the original thread. Thanks for your input, I might be able to afford a fan for overclocking... my friend recommended the Cooler Master Hyper 212+
Old November 19, 2009, 08:01 PM
stoanee's Avatar
Yes the Coolermaster is good value. Make sure you pricematch!
heatware
Old November 19, 2009, 08:39 PM
AmuseMe's Avatar
Isn't Black Friday the American Boxing Day? But you are buying from NCIX, who wont be doing Black Friday because they are Canadian -will they?
Old November 19, 2009, 08:42 PM
Not sure =/
Maybe I should wait until Cyber Monday instead?
Old November 19, 2009, 08:44 PM
Many Canadian Retailers have sales on black friday even if it is american. So he can hope at least and technically ncix has an american site too so I assume they would have deals for there and would have to put on canadian too otherwise people would complain (not sure on this could be wrong)
Old November 19, 2009, 10:06 PM
Default re
Hi sir there are some suggestion:
Notice that this is my personal opinion, your research may go in different direction...
I see it at 120$, why not get 2X 60$ 500g caviar black and put them in raid?
Suggestion...
$212.00 Intel Core i5 750 Quad Core Processor Lynnfield LGA1156 2.66GHZ 8MB Cache Retail Box
choice if you do video editing, total brute for overclocking
$149.97 Cooler Master Haf 932 Full Tower Black EATX Case 6X5.25 1X3.5 5X3.5INT No PSU USB eSATA 1394 Audio
For your need, you might want to go for a HAF 922, smaller yes, but will do the job if you overclock by air or not. I personnally own an haf 932, but i got a dual watercooling loop. 2 pump, 2 rad, tank, fan, etc... I need that space. But on the other hand, the 932 is a perfect case for the long run. There it depend on your needs.
$74.74 Razer Lycosa Gaming Ultrapolling Keyboard Black USB Programmable Blue Backlight NON-SLIP Keys
You like it, it kick ****, perfect! To my way this is personal...
$297.77 MSI Radeon HD 5850 725MHZ 1GB GDDR5 4.0GHZ 2XDVI HDMI Display Port DIRECTX11 PCI-E Video Card
Good luck finding one!
This seem to be a gaming rig...
Not sure...
There it is!
Old November 20, 2009, 07:17 PM
Bump up for a friend, so what would be a better p55 board?
Old November 21, 2009, 06:13 PM
Updated some prices, case, ram and added heatsink
Potential i7 Build, comments welcomed Arinoth New Builds 26 June 25, 2009 01:41 PM
New Build - Need some opinions! bedouin New Builds 24 March 9, 2009 09:12 PM
New Build need opinions FrankyG New Builds 11 September 22, 2008 10:00 AM
New Build - Opinions Please. Loejack New Builds 12 September 17, 2008 01:24 PM
Opinions on build? MarX New Builds 7 August 28, 2008 04:00 PM
