-   -   First Gaming Build (http://www.hardwarecanucks.com/forum/new-builds/25275-first-gaming-build.html)
anomaly0 November 7, 2009 07:54 AM
First Gaming Build
This is my first ever build ever - I have the assistance of a friend if I get stuck but I want to give it a shot myself first.
Case: Thermaltake Element G
Newegg.com - Thermaltake Element G VL10001W2Z Black ATX Mid Tower Computer Case - Computer Cases
Power Supply: CORSAIR CMPSU-850HX 850W
Newegg.com - CORSAIR CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply - Power Supplies
Motherboard: EVGA E758 LGA 1366 Intel X58 ATX
Newegg.com - EVGA E758-TR 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Intel Motherboards
CPU: Intel Core i7-950 Bloomfield 3.06GHz
Newegg.com - Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Processors - Desktops
Memory: CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 8-8-8-24
Newegg.com - CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D - Desktop Memory
GPU: Radeon HD 5870 1GB
Newegg.com - SAPPHIRE 100281VXSR Radeon HD 5870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
Hard Drive: WD Caviar Black 500GB 7200 RPM 32MB
Newegg.com - Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Disk Drive: SAMSUNG 22X DVD±R DVD Burner
Newegg.com - SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD±R DVD Burner - CD / DVD Burners
So thats what I am thinking about getting.
Opinions? Suggestions? Am I completely wrong? Same performance for lower price?
(price not really an issue though)
Thanks for your Help :biggrin:
Bond007 November 7, 2009 08:21 AM
That is definitely a powerful computer, though it will put a dent in the bank account.
I am not familiar with the case, so I will let someone else guide you on that.
The CPU is excellent, but priced accordingly. If you can overclock then you can save money and go with the i7 920. Also you could consider switching to the i7 860 and P55 platform.
The power supply is something many people will likely tell you to switch. It may be fine, but it is always a safe bet to go with Corsair or Seasonic.
Ritz November 7, 2009 09:25 AM
Do you really want to spend $500+ on a DirectX 10 card? The GTX 295 is on the verge of becoming obsolete. Whether that happens with the 5970/5870x2 or with what ever Fermi ends up becoming... It looks to me like you are looking for bleeding edge, but I just wouldn't get a GTX 295 right now. I would compromise on the video card right now, and wait it out for the next generation.
Looking at the $/MB ratio on that VelociRaptor, I would pass and jump straight to an SSD (speed, speed, speed). If you are running Windows 7, "libraries" will make it easy to put personal files on a second more spacious and much cheaper drive. For example, I might play around with the idea of a 30 or 60 GB SSD (that supports TRIM, like OCZ's Vertex or Agility) that would run the OS, key programs and a game or two, and then get a 500 GB secondary drive for everything else. Yes, the ratio gets even worse, but the performance can't be touched. This is something I really wish I did, anyway.
For example:
Newegg.com - OCZ Agility Series OCZSSD2-1AGT60G 2.5" 60GB SATA II MLC Internal Solid state disk (SSD) - Solid State Disks paired with
For the sake of argument.
Kayen November 7, 2009 10:13 AM
Agreed, with both Ritz and Bond007. i5 and i7 860 isn't that great of a performance drop off for $92384903802394 less.
And with the speeds of the Caviar Black Drives, they make velociraptor pricing look silly, and with SSD's looking to be the future i would do that route as well.
And GTX295 is NOT worth it at this point.
anomaly0 November 7, 2009 11:58 AM
Thanks for the advice, build updated to reflect choices.
Further advice and stuff is fine :)
Fox November 7, 2009 01:30 PM
I'd going for the HX850W over the Toughpower.
HX850W:
Modular
80 Plus Silver (More efficient)
6x 6+2pin PCI-E
Single Rail
$199.99 @ newegg ($169.99 after MIR)
Toughpower:
Modular
80 Plus (Less efficient)
2 x 6-Pin, 2 x 8-Pin
Multiple Rails
$209 @ newegg
You could also go with the HX750 as it like it's big brother, but comes with a combo deal with the EVGA E758-TR plus has an additional discount on it.
Bond007 November 7, 2009 07:16 PM
You build is looking better now.
somecanadianguy November 7, 2009 07:21 PM
Looks like a nice build.
Definately consiider the i7 920 though...
Can save a couple hundred $$$ and it's just as good (easy to OC to 950 performance and beyond).
anomaly0 November 7, 2009 08:00 PM
Thanks,
Never OC'd anything myself but I guess I can give it a shot.
Thank you everyone for your advice and feedback.
:clap:
crazyhorsejohnny November 7, 2009 08:08 PM
Dude you should put where you're from.
