Old November 5, 2009, 08:45 PM
Default 8800gt to 5850 or keep 8800gt and upgrade to i5 from e6600?
I really want to upgrade to an Intel i5 750 based system with an ati 5850 video card
and 4gb of ram but I really cannot justify starting over from scratch with a new system build. So really I'm looking for some input, would it be best to just swap out my 8800gt for a 5850, keeping the rest of my system untouched, or would it be better to keep my existing 8800gt and put that into a intel i5 based system and upgrade the video card later?
The biggest thing I want is bang for the buck, and if I upgraded the video to a 5850 would my core 2 duo @ 3ghz completely bottleneck the video card?
existing system specs:
Lian Li PC-7 Plus II Case
Intel Core 2 Duo E6600 @ 3Ghz
Gigabyte GA-965P-S3
WDC Black WD1001FALS 1Tb HD
Lite-on DVD-RW SOHW 1693S
Zotac 8800 GT AMP! 512Mb
Patriot 4GB PC2-6400 Ram
ram + mb + cpu = $400ish
radeon 5850 = $300ish
Intel Core i5-750 2.66Ghz @ 4Ghz, ASUS P7P55D-E Pro, 4GB G.SKILL Ripjaws cas7, WDC 1Tb WD1001FALS, WDC 640Gb WD6400AAKS, OCZ Vertex 2 Extended Sandforce 60GB, GIGABYTE Radeon HD 7950 3GB 384-bit GDDR5, Corsair Hydro H70, LG GH24NS50 DVD 24x Burner, Antec Eleven Hundred, Antec TruePower New TP-750 750W, Microsoft Windows 7 Ultimate x64
http://i571.photobucket.com/albums/s...osmond/1-1.jpg
http://i571.photobucket.com/albums/s...benchmarks.jpg
Old November 5, 2009, 08:51 PM
Silvgearx's Avatar
Of course go for the GPU.
Try to get your E6600 higher, let say somewhere @3.4ghz-3.6ghz.
and it seems like your gaming at 1680x1050.
I would love to see some inside pics of your build :P
3.0charlie's Avatar
I'm afraid so. You may want to do some research, but as good as the E6600 was, it's old technology nowadays.
From NCIX: NCIX.com - Buy NCIX P55 Bundle Deal Core i5 750 2.66GHZ Kingston 4GB DDR3-1800 C8 Gigabyte P55-UD4P SLI Motherboard - 750-UD4P-4GB-KINGSTON In Canada. Good combo.
Choosing the Asus P7P55D and some 4Gb DDr3 on sale you could save even more.
Hydro-Quebec is salivating...
Old November 5, 2009, 08:53 PM
SneakySnake's Avatar
Your C2D at 3 GHz won't bottleneck the 5850 to much. I'd go for the GPU upgrade, you'll see a lot higher fps boost then you would if you upgraded to i5. If you want to eliminate a CPU bottleneck for a lot cheaper you could purchase a Q9550 or another C2Q and drop it into your existing setup.
Here's some numbers with the E8400 @ 3.0 and 3.7 with a 5850
i5 8400 || Strix 1080 Ti || 16 GB DDR4 3000Mhz
Old November 5, 2009, 09:18 PM
Kylzer's Avatar
GPU first then maybe a new cpu later the unless your some sort of encoding freak you wont need a new cpu for a while.
CPU: i7 920 @ 4.4ghz
MOBO: GA-X58-UD4P
RAM: Corsair 3x2GB 1600mhz
GPU: PowerColour HD 4890 Xfire
PSU: Corsair HX850
Case: CMD690
Old November 5, 2009, 11:15 PM
Kayen's Avatar
+1 on GPU upgrade. Just oc that E6600 and it'll be no probs, you'll get a nice fps +++.
Old November 5, 2009, 11:29 PM
Fox's Avatar
Fox Fox is offline
Choosing the P55-UD4P/i5 combo from newegg.ca, G.SKILL Ripjaws 4GB DDR3-1600, then entering the promo code "MKTBDAY" (10% off for there aniversary). Came to ~$465 after tax/shipping. Right now w/ the 10% off anything over $250, you can get some nice deals.
Odds are you'll notice the change more when upgrading the GPU then you will CPU/MB/Ram, especially if you only really use it for gaming. Like they mentioned above, if you get the GPU, just OC the CPU a little more and bottlenecking shouldn't be too much of an issue I believe.
Old November 6, 2009, 05:23 AM
gingerbee's Avatar
have to go with charlie on this one i think you'll see a much better over all improvement from a cpu MB upgrade the card you have will play most games a pretty good fps
Old November 6, 2009, 05:55 AM
Dr_BenD_over's Avatar
Fallen Folder
Gaming wise, I'd go for a 5850 over the CPU upgrade (If you can find one). I'm still sticking with my Q6600 @ 3.0 after 2 years and it still cuts the mustard.
All's well that's Haswell
Old November 6, 2009, 06:06 AM
Soultribunal's Avatar
I vote to go with a new Platform, with a memory controller and PCI-e controller on board the new i5 chip will help streamline everything better.
Then down the road get a better GPU.
ST
www.realhardwarereviews.com
[FS] Selling BFG 8800Gt, E6600, EAX1950pro, Zalman CNPS 7700 MrFoxx Buy/Sell & Trade 12 May 28, 2009 01:42 PM
[FS] evga 680i A1, BFG 8800gt, XFX 8800gt oksir Buy/Sell & Trade 2 February 13, 2009 08:55 PM
[FS] 8800GT @80, Koolance 8800GT waterblock, XFX680i LT @70, ATI 1900XTX, AMD Opteron 144 pakultra Buy/Sell & Trade 12 January 28, 2009 09:42 PM
Is an 9800GTX+ SC a good upgrade from an 8800GT XT? Gameplaywarrior Video Cards 3 September 23, 2008 07:39 AM
Newbie question: XFX 8800gt XXX vs. eVGA 8800gt NorthernPike Video Cards 1 July 22, 2008 07:12 PM
