Old November 2, 2009, 07:43 PM
Default Here's a build question....
Hi, just curious after reading some posts, What is the best combo of parts...
An i7 build with a 4870 card or an i5 build with a 5850... both look like they will run about the same price.
Old November 2, 2009, 07:46 PM
Lamb's Avatar
i5 / 5850 for sure!
Old November 2, 2009, 07:49 PM
martin_metal_88's Avatar
I5 / 5850... It;s way better balanced. Getting a I7 with 4870 is like...having a ******* ugly girls with the biggest boobs you have ever see.
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 2, 2009, 07:53 PM
Ask for more.
Not really a good example, cuz having the biggest boobs would mean, she'd be ugly(nothing going for her). I would tend to ask the purpose of the computer before giving out an answer. If gaming is involved, the 5850 will definitively give better performance tho.
Old November 2, 2009, 07:59 PM
The purpose would be 80% video/animation work, 10% gaming, 10% surfing. As long as I could play itunes, do my work in Flash Professional, keep my mail open, and surf a bit on a break.. that would be ideal. And then play games like Bioshock on the weekends. :)
Old November 2, 2009, 08:23 PM
MpG's Avatar
MpG MpG is offline
Do you know what does the video/animation program uses for it's heavy crunching? If it's CPU, and the program can take advantage of hyperthreading, i7 could have a significant advantage over i5. But if it uses the video card, the 5850 will be king (assuming you can even find one for sale at this time). Also, make sure you include enough RAM regardless.
Old November 2, 2009, 09:35 PM
Polygon's Avatar
Also make sure you have enough RAM, I run out fairly often if I'm working on massive projects and have internet browsers and other applications open.
'Do not wish for easier lives, wish to be stronger men'
DreamRealeSports.com
My first post: NEW PC build, Overclocking question drenerk Overclocking, Tweaking and Benchmarking 0 November 1, 2009 11:25 AM
Yet Another Build Question Surfer_2099 New Builds 9 October 21, 2009 05:54 AM
Build Question for Radeon Options Surfer_2099 Video Cards 4 September 18, 2009 01:03 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
Quick Build Question FunkyJunky Video Cards 3 March 23, 2008 02:59 PM
