Old October 10, 2009, 01:35 PM
Default Need advice with i7 in a Silverstone SG03
Hey, I'm building an i7 system, and need some advice about the case I'm interested in using. I really like the size and looks of the Silverstone SG03. My concern is cooling though. It is a pretty small case which is what I like, but the i7 runs pretty hot right?
The system has the following:
i7 920
Intel DX58SO
6GB DDR3 1600
eVga gtx 275
Corsair TX750 PS
WD 1TB HD
I was either going with the cool master V8 or Silverstone NT06 cooler. I was planning on overclocking it to maybe 3-3.5GHz, nothing crazy.
How's all this going to fit in the system? Are there going to be cooling issues?
Thanks for any help
Old October 10, 2009, 02:27 PM
CMetaphor's Avatar
Quadfather
V8 wont fit AFAIK.
I've successfully used the following in that same case: Coolermaster GeminII (passive), NT06 (didnt perform amazingly), Corsair H50 and recently (with some modding) an Asetek LCLC-240mm. To get the lclc to fit though, i had to make the front hard drive rack unuseable by removing its side bracket. But it does work .
Old October 10, 2009, 03:46 PM
Thanks for the info! I've decided to go with the Cool Master Sniper instead. I've read some good reviews about that case. And I know I'm not going to get into cooling and/or expansion issues with that case. It's too bad, that silverstone case looks really good.
Silverstone LC-03 JD HTPC Systems & Software 9 March 19, 2009 09:49 PM
Silverstone LC20 buzzkill HTPC Systems & Software 9 February 25, 2009 04:58 AM
Silverstone TJ07 Cadence Cases 5 December 3, 2008 09:03 AM
Comment Thread for Silverstone Sugo SG03 Case Review SKYMTL Cases 3 August 22, 2007 09:36 AM
