Old September 30, 2009, 03:41 PM
Default Low bidget build!
Hey,
I was wondering if you guys would be very nice and help me find the best bang for the buck ;)
I'm looking to spend around 500-600$
Need:
Mobo
Ram
Gfx
Psu
Harddrive? not sure yet....
Cd/DvD burner
Cables..
Not really looking to game with this rig, its just to go on the internet and do some school work. THANKS VERY MUCH!!!
Old September 30, 2009, 05:15 PM
Kayen's Avatar
No gaming ?
I would say IGP + Quad would be plenty.
Waiting for the NCIX specials to start but off top of my head:
Athlon II X4 620 Combo w/ 785g mobo DDR3.
4 DDR3 Ram
Graphics built into mobo.
Corsair 400w PSU
HDD: Your choice, but WD 640gb Blacks are reccomended quite often here.
DVD: Any SATA one ..
If you need a case: NZXT Beta/m59, Antec 200/300, CM690, are all within your price range.
I'll edit after the sale starts. ;p
EDIT:
NCIX.com - Buy NCIX Value Bundle Deal AMD Athlon II X4 620 AM3 CPU & Gigabyte MA785GM-US2H DDR2 785G Motherboard - X4-620-MA785GM-US2H In Canada. $200
NCIX.com - Buy Patriot Extreme Performance 4GB 2X2GB PC2-6400 DDR2-800 CL5-5-5-12 EPP Dual Channel Memory Kit - PDC24G6400ELK In Canada. $70
NCIX.com - Buy OCZ FATAL1TY 400W ATX12V 20/24PIN Power Supply Active PFC 120MM Fan 80PLUS - OCZ400FTY In Canada. $40
NCIX.com - Buy Seagate Barracuda 7200.12 500GB SATA2 3.5IN 8.5MS 7200RPM 16MB Hard Drive OEM *3YR MFR Warranty* - ST3500418AS In Canada. $50
NCIX.com - Buy Antec Two Hundred Mid-Tower ATX Gaming Case Black 3X5.25 6X3.5INT 1 SATA Hot-Swap Bay No PS - TWO HUNDRED In Canada. $50
NCIX.com - Buy LG GH22NS50 Black 22X SATA DVD Writer OEM - GH22NS50 In Canada. $30
$440 before taxes & shipping (; .
Old October 1, 2009, 01:48 PM
Thanks!
Old October 1, 2009, 02:07 PM
geokilla's Avatar
Prebuilt is the way to go.
Old October 1, 2009, 02:09 PM
Kayen's Avatar
The build kills any prebuilt ... even with any added cost of OS + monitor.
Old October 1, 2009, 02:37 PM
Originally Posted by Kayen View Post
No gaming ?
4 DDR3 Ram
Corsair 400w PSU
EDIT:
Thanks for all this info but i was wondering if you could also help me get a good gfx card for about 100+ dollars and a little bit better power supply maybe around 600 w
Thanks ahead of time.
Old October 1, 2009, 03:50 PM
geokilla's Avatar
Why do you want a GPU if you're doing little gaming on it? Having said that, look into the ATI 4850 or 4830 if you can find one for cheap. PSU, OCZ StealthXStream 500W. I got the StealthXStream on another rig and it's pretty good for the price I got it.
Are you going to overclock?
Old October 1, 2009, 03:51 PM
The 400W power supply can handle that CPU AND a Radeon 4770 if you don't overclock. (from experience of running a dual core and a hungrier Radeon 4850 using a 375W power supply).
I say save your money and add a GFX card if you find use for it.
EDIT: Geokilla beat me to one of the comments :P
Old October 1, 2009, 04:45 PM
The reason for this is because i already have a gaming rig. I need another computer in the house for my sister to study on.... (she's going to college for nursing)
Very low budget build Lamb New Builds 5 November 20, 2009 01:45 PM
Low low budget build... help please somecanadianguy New Builds 47 October 8, 2009 04:20 AM
Low Noise Workstation Build jwebby New Builds 0 September 10, 2009 08:28 PM
Intel E5200 low Budget Gaming Build DarXViruS New Builds 14 June 27, 2009 12:00 PM
Low/Mid-range 3D modeling build Osmo New Builds 9 December 1, 2008 09:07 AM
