Old September 24, 2009, 02:11 PM
somecanadianguy's Avatar
Default Low low budget build... help please
I need help putting together a really cheap pc.
It only needs to be better than a Compaq Presario (has a celeron, geforce 6200, 512mb ram... it sucks ).
Budget will be low, but I'd rather try to put what money I can into a new system rather than upgrade this POS.
Only parts worth keeping will likely be the dvd drive and fans... maybe the case if I can find a mobo that fits.
Keep cost as low as possible... cheaper the better.
Again, I'm only looking for a small upgrade from a crappy Compaq.
No i5 or i7... probably not even looking at a quad unless it's dirt cheap.
Will be used mostly for internet, and some 2d work.
Old September 24, 2009, 02:16 PM
geokilla's Avatar
What does low mean? If you want it at like $500, go buy a pre-built from Staples or Best Buy or whatever.
Old September 24, 2009, 02:26 PM
Lower than $500...
I'll be getting used parts if I can find them.
Just want help deciding what to do.
Old September 24, 2009, 02:35 PM
That's looking pretty good.
What about RAM and video card?
I want to try and reuse the case (presario s6010v) and psu if possible (think the psu is 400w... might be 350).
Can anyone get cost down even lower?
I will consider used parts.
Old September 24, 2009, 02:38 PM
Arinoth's Avatar
Will it be used for gaming or anything like that, it looks like it comes with an on board GPU
Here I am: here I remain
Old September 24, 2009, 02:43 PM
Jon_di2's Avatar
You can always check out barebones at tiger, some are pretty decent deals, expecially if your looking for lower end:
Barebone, Barebones, Barebone Computer System Kit, Barebone Kits, PC Barebones, Asus Barebone Kits, Barebone PC, Shuttle Barebone Kits. Mini Barebone PC at TigerDirect.ca
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old September 24, 2009, 02:44 PM
Perineum's Avatar
BAH! I never suggest pre built. You end up with an EOL case and psu that way.
NCIX.com - Buy AMD Athlon 64 X2 5200+ Dual Core Processor AM2 2.7GHZ 2X512KB 65W 65NM Retail Box - ADO5200DOBOX In Canada. $64
NCIX.com - Buy Gigabyte GA-MA74GM-S2 AMD740G mATX AM2+/AM3 1PCI-EX 2PCI SATA2 RAID VGA Sound GLAN DVI Motherboard - GA-MA74GM-S2 In Canada. $60
NCIX.com - Buy Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio - THREE HUNDRED In Canada. $58
Anyway, that's the idea. The more parts you reuse the cheaper it gets of course.
Can swap out that case for one with a PSU as well for $7 more. It's not THAT horrible, I've used it a few times already.
NCIX.com - Buy Inwin Z589T mATX Mini Tower Case Black 2X5.25 2X3.5 1X3.5INT 350W Front USB & Audio - Z589T.J350BFU2AD In Canada.
Old September 24, 2009, 02:46 PM
Perineum's Avatar
You'd have to look very closely at that PSU and case. I wouldn't be suprised if they were simply incompatible.
Old September 24, 2009, 02:49 PM
Don't know about the case... the psu is one I added about a year ago.
Not sure if I can reuse either but want to at least see if it's possible.
Definately want to get a video card, but it doesn't have to be very good as it won't be used for gaming (just want better than the geforce6200 that's in the compaq).
I have to go out for an hour but would like to hear more suggestions.
Would like to get this sorted out by the end of the month.
Looking to build low budget Security Camera System, any help? The MAX New Builds 5 July 7, 2009 09:43 AM
Intel E5200 low Budget Gaming Build DarXViruS New Builds 14 June 27, 2009 12:00 PM
low budget psu CTA Power Supplies 8 March 28, 2009 03:30 AM
low budget case CTA Cases 18 March 22, 2009 12:00 AM
Scythe Shuriken Low Low-Profile CPU Cooler Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
