  #41 (permalink)
Old September 29, 2009, 03:08 PM
somecanadianguy's Avatar
Lazy is fine... anything helps .
Haven't seen screenshots, but the motherboard is guaranteed by the seller to unlock the chip.
I did a little research and that seems to be what others are saying.
He's got 4gb DDR3 too... all for $270 shipped!
Sounds like a good deal.
The Athlon II x4 620 + mobo + 4gb ddr2 is $30 more, but comes with warranties and is definately a quad-core.
How much better would that system be if it truly does unlock?
Will the 4th core work properly?
Would it be better even if it didn't unlock?
Not too likely it will be overclocked much if at all...
Won't be doing much gaming...
*edit*
Got to see a screen of the chip in another mobo he's selling.
Says the Gigabyte will unlock though.
Cpu-z validation shows this:
CPU Arch : 1 CPU - 4 Cores - 4 Threads
CPU PSN : AMD Phenom II X4 20 Processor
CPU EXT : MMX(+) 3DNow!(+) SSE SSE2 SSE3 SSE4A x86-64
CPUID : F.4.2 / Extended : 10.4
CPU Cache : L1 : 4 x 64 / 4 x 64 KB - L2 : 4 x 512 KB
CPU Cache : L3 : 6144 KB
Core : Deneb (45 nm) / Stepping : RB-C2
Freq : 3612.23 MHz (200.68 * 18)
  #42 (permalink)
Old September 29, 2009, 03:32 PM
Originally Posted by geokilla View Post
P.S. Make sure that the GA-MA770T-UD3P has A.C.C. so you can unlock it into a quad core. That option/feature is a must.
I think I read that the board just needs a BIOS update to use that feature.
  #43 (permalink)
Old September 29, 2009, 04:38 PM
I just went with the Athlon II x4 620 + Gigabyte AM3 mobo.
Got them and a Ultra Kaze 120mm fan to put in my rig for $214.11 shipped.
My gf was kinda uneasy about the whole 'unlocking' idea, and after all, it'll be her computer.
Thanks for the help
Now go ahead and tell me what a bad choice I made and that I could have done better...
Anyone with parts for sale to help me with this build check out my WTB thread...
http://www.hardwarecanucks.com/forum...tml#post263234
  #44 (permalink)
Old September 30, 2009, 03:38 PM
So far, I think the build is looking decent for the money.
Athlon II x4 620
Gigabyte MA785GMT-UD2H
2x2gb Crucial ddr3
With taxes and shipping I have spent around $270 so far (just working out details on the RAM sale).
A little more than I wanted to spend, but decided to stretech it and get the cheap quad instead of a dual.
How's this looking for a budget build?
Am I on the right track here?
  #45 (permalink)
Old September 30, 2009, 05:18 PM
Kayen's Avatar
You're on track. Quad core w/ 4gb DDR3 ram at that price .. it's pretty good way to start off a budget system (;
  #46 (permalink)
Old September 30, 2009, 05:44 PM
Definately different from my i7 build.
I think this is almost more fun really... well, almost...
  #47 (permalink)
Old October 7, 2009, 09:42 PM
CPU, motherboard, and RAM are here.
Going to order a couple more things tonight or tomorrow.
Anyone used either of these cases?
NCIX.com - Buy ASUS TA-D54 ATX Mid Tower Case BLACK/SILVER Front Audio USB No PSU - TA-D54 In Canada.
NCIX.com - Buy ASUS TA-B32 Black Yellow Mid ATX Tower No PS with USB Audio - TA-B32 In Canada.
  #48 (permalink)
Old October 8, 2009, 04:20 AM
If I get this mATX case...
NCIX.com - Buy Compucase 6K28 mATX Case Black 2X5.25 2X3.5 1X.3.5INT W/ Front USB & Audio No PS - 6K28B In Canada.
Can I fit a PSU 150 x 160 x 86mm (W x L x H)?
Anyone know??
Looking to build low budget Security Camera System, any help? The MAX New Builds 5 July 7, 2009 09:43 AM
Intel E5200 low Budget Gaming Build DarXViruS New Builds 14 June 27, 2009 12:00 PM
low budget psu CTA Power Supplies 8 March 28, 2009 03:30 AM
low budget case CTA Cases 18 March 22, 2009 12:00 AM
Scythe Shuriken Low Low-Profile CPU Cooler Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
