Hi all,
This build will replace the second (butchered Pentium 4) computer in my sig. A few numbers convinced me:
P4 rig's power consumption from wall:
123W PPD:
105.94
0.86 PPD / W
That's right... LESS than 1 folding PPD per watt. Given that my laptop can produce 1700PPD while consuming 63W (Linux SMP), the P4 rig is so inefficient that I'm retiring it from folding after the contest.
As per sticky:
1. PURPOSE: NAS + Bittorrent + Subversion + Folding :P
I don't need any specialized RAID card, and I have very low requirements for file transfer speed (e.g. I'm still using 10/100 and don't mind)
2. BUDGET: <=$500 *NOT INCLUDING THE HARD DRIVES*
** I am also enforcing a WATTAGE BUDGET: <
150W estimated. If I go over 150W, I will stop folding on the CPU of my main rig to compensate.
3. WHERE TO BUY: Canada, case from Ottawa
4. FANBOY: *none*
5a. REUSING CURRENT PARTS: SATA DVD-ROM, 250GB SATA and 250GB IDE HDD; I may throw in my 120 GB mobile HDD for the OS if it's strange enough
5b. I have access to free MSDNAA Windows - any Windows (business/desktop or server) from 2000 to 7 when it comes out, or I can use Linux if the rig will fold on CPU only
6. Looked in SIMILAR THREADS? ...not really
Actually, I plan to UNDERVOLT. Recommendations for good undervolters are appreciated.
In the next 30 days...
Current idea for parts:
MOBO
NCIX.com - Buy Gigabyte GA-MA785GMT-UD2H AMD785G mATX AM3 PCI-E DDR3 Video Sound GLAN CrossFireX HDMI Motherboard - GA-MA785GMT-UD2H In Canada.
CPU
AMD Athlon II X2 240 Dual Core Processor Socket AM3 2.8GHZ 2MB Cache 65W Retail Box - DirectCanada
Memory <RAM of the Week>
Case Antec-NSK-4480 Super Mini Tower with high efficiency 380w Power supply
Everbest Computer
I know a DDR3 motherboard is overkill, but I like new tech and DDR3 theoretically takes up less energy
- If you really think a AMD + DDR2 platform will be best, I'll use the M3A78-T from my main as the mobo and upgrade my gaming rig to a DDR3-based platform. (3 out of 4 desktops in my place have DDR2; I'm sick of it
