Old September 13, 2009, 04:31 PM
Default Fan connecting to motherboard problem
Hi
I'm in the process of building my first custom PC.
I think I got a problem with my case (ANTEC Nine Hundred Two) having too many fans and my Motherboard (ASUS P5QC) doesn't have enough connectors for it.
Here are the links for the specs of the Case and Motherboard.
Case: CIPC - L'endroit par excellence pour un pc de haute performance
Motherboard: P5QC-ASUS P5QC S.775 INTEL P45/ICH10R ATX 1PCIE X16 DDR2X4 DDR3X2-MOTHERBOARDS-COMPONENTS- SOHODIFFUSION.COM
If anyone could check for me if there's enough connectors for the fans that come with my case (not including the 2 optional ones)
It'll be great if you can tell me what I should look for on the motherboard spec that tells me if I got enough connectors for the fans.
Old September 13, 2009, 04:36 PM
Arinoth's Avatar
You know you don't have to have every single fan connected to the motherboard. You could have them left stock speeds connected to the PSU or you could buy a 5.25" bay fan controller as well
Here I am: here I remain
Old September 13, 2009, 04:40 PM
thnx for the reply, im really new at this.
If I understand,
I can connect the fans straight to the Power Supply instead of the motherboard?
What's the advantage of having it connected to the MB?
Old September 13, 2009, 04:44 PM
Arinoth's Avatar
Some fans may not even have the connector to motherboard. The advantage of having them connected to the motherboard or a fan controller is that you can control the fan speed, speed it up if you want more cooling, speed it down if you want it more silent. If they are just connected to the power supply they run stock speed and that's about it.
Old September 13, 2009, 04:46 PM
THank you very much! I understand now
ATI HD4850 fan noise problem Chris Video Cards 20 August 12, 2009 07:50 AM
I think my motherboard is screwed how can I tell if that what is my problem? Shadowmeph CPU's and Motherboards 5 July 20, 2009 07:15 AM
Asus P5Q-E MB wake up fan settings problem resolved 486 CPU's and Motherboards 0 February 26, 2009 10:06 PM
Motherboard fan controlling? chibi_man Troubleshooting 7 July 15, 2008 09:52 PM
connecting a water pump to a fan controller Corpus Masochist Water Cooling 8 August 29, 2007 09:11 PM
