Old September 11, 2009, 01:34 PM
Default Need help on 2 builds(budget)
Hi, due to certain event I need advise on some building plan for friends.
Build 1- My friends 4 years old system went dead and looking for a basic build(350-400 dollar tax in)
Build 2- My friend told me he got hooked by another friend for a Phenom system for 650 tx in. Computers: Desktop Computers: HP Pavilion Computer featuring AMD Phenom X4 Quad Core 9750 (M9500Y) - English -Refurb - Online Only | Best Buy Canada Web Store I felt going thru online building can reach lower price/better gear point as university license is next to nothing. Wanted to see if a possible building plan that can persuade him from going to the evil side.
Build 1, Build 2 is below
Basic usage, occasional light gaming(wc3, maple story, heroes of newerth. Also possibly looking into next gen MMO's with low quality setting)
400
Any online store(Ncix,TD,CC,DC)
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None
Hard drive, cd rom. And possibly the old case which is an antec sonata(would swap psu I assume)
Yes, but seems like unable to find with budget this range
default. It's not my rig
Anytime, but I think I will go thru 1 month part hunting.
Build 2
Basic usage, occasional light gaming(wc3, maple story, heroes of newerth. Also possibly looking into next gen MMO's with medium quality setting)
650
None, but would want to stay phenom II and Nvidia gfx card to give him direct comparisn.
No
No, due to restriction of my search. Seems like ATI cards is more popular at this price range.
Thanks!
Old September 11, 2009, 02:44 PM
Kayen's Avatar
Prices are before rebates.
Build 1 Here we go:
Reuse optical drive & case.
Mobo/CPU: NCIX.com - Buy NCIX Value Bundle Deal AMD Athlon II X2 245 & Gigabyte MA785GM-US2H DDR2 Motherboard -UNASSEMBLED - 785GM-X2-245 In Canada. $155
PSU: NCIX.com - Buy Seasonic M12 II 500W EPS12V 20/24PIN ATX Modular Power Supply Active PFC 80PLUS 6PIN PCI-W 120MM Fan - SS-500GM In Canada. $75
RAM: NCIX.com - Buy Patriot Extreme Performance 4GB 2X2GB PC2-6400 DDR2-800 CL4-4-4-12 EPP Dual Channel Memory Kit - PDC24G6400LLK In Canada. $68
HDD: NCIX.com - Buy Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - WD6401AALS In Canada. $76
$374 before taxes + s&h.
Built 2:
MOBO: NCIX.com - Buy Gigabyte GA-MA770-UD3 ATX AM2+/AM3 AMD770 PCI-E16 2PCI SATA2 RAID 1394 HD Sound GBLAN Motherboard - GA-MA770-UD3 In Canada. $88
PSU: NCIX.com - Buy AMD Phenom II X4 955 Black Edition Quad Core Processor AM3 3.2GHZ 8MB Cache 125W 45NM Retail Box - HDZ955FBGIBOX In Canada. $290
CASE: NCIX.com - Buy Coolermaster cm 690 Mid Tower Black ATX Case 5X5.25 5X3.5INT No PS Front USB Sound Firewire & eSATA - RC-690-KKN1 In Canada. $86
Video: NCIX.com - Buy ASUS GeForce 9600GSO V2 550MHZ 512MB 1.4GHZ DDR3 PCI-E VGA DVI HDMI HDCP Video Card - EN9600GSO/DI/512MD3/V2 In Canada. $60
OPTICAL: NCIX.com - Buy LG 16X DVD-ROM Drive Internal SATA OEM - DH16NS10.AVAA10B In Canada. $24
$767 before taxes and shipping, however if you pricematch i'm sure it'll be able to come down a bit.
I got the Phenom X4 955 for $220 from DC. Use price canada's engine right here on HWC .
Old September 12, 2009, 08:34 AM
hossdaddy's Avatar
here's my 2 cents on Build 1,
AMD Athlon II X2 240 (65W) Dual-Core Socket AM3, 2.8GHz $73.99
Gigabyte GA-MA78GM-US2H Socket AM2+ AMD 780G $72.99 after mir
2 x Crucial (CT25664AA800) PC-6400 2GB DDR2 800Mhz $53.98
Corsair CMPSU-400CX 400W Power Supply $40.99 after mir
Sapphire ATI RADEON HD 4670 512MB $72.99
Total: $346.94 - $32 in mir
Build 2,
AMD Phenom II X2 550 Black Edition (95W) Dual-Core Socket AM3, 3.1GHz, $119.99
Gigabyte GA-MA785GM-US2H Socket AM3 AMD 785G + SB710 Chipset ATI $97.99
this mobo can unlock the 3rd & 4th cores if the cpu allows!
Antec Sonata III Quiet Super Mid Tower w/ 500W PSU Metallic Charcoal Color (Canada Computers Exclusive) $119.99
Western Digital Caviar Black (WD5001AALS) 500GB SATAII 7200RPM 32MB Cache $64.99
Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066MHZ $69.99
Samsung SH-S223B/BEBE SATA $32.99
BFG GeForce GTS 250 (BFGEGTS250512OCE) Nvidia GeForce GTS 250 Chipset (750Mhz) Shader Clock (1836Mhz) 512MB $119.99 after mir
Total: $625.93 after mir.
If its just light gaming under 1680x1050 then you could just use the 4670 like in the above build and save $50.
These guys have stores all across ontario so you may be able to grab it vs. shipping.
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old September 17, 2009, 03:26 PM
thanks for the replies, I've made a build list for the 400$ computer and want to hear from it...
NCIX Value Bundle Deal AMD Athlon II X4 2.6GHZ AM3 CPU & Gigabyte MA785GM-US2H DDR2 785G Motherboard 199.99
x Gigabyte GA-MA785GM-US2H AMD785G mATX AM2+ PCI-E DDR2 Video Sound GBLAN CrossFireX HDMI Motherboard
1 x AMD Athlon II X4 620 Quad Core Processor Socket AM3 2.6GHZ 2MB Cache 95W Retail Box
1 x FREE OCZ Platinum XTC REV.2 PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-15 240PIN DIMM Dual Channel Memory Kit
Corsair VX450 450W ATX 12V 33A 24PIN ATX Power Supply Active PFC 120MM Fan 71.99-22=49.99
Gigabyte Radeon HD 4850 625MHZ 512MB 1.92GHZ DDR3 PCI-E CrossFireX DU-DVI-I HDCP HDTV Out Video Card 119.99-10(PM)-20=89.99
pm it with directcanada I should get 422.81 with 42 dollar MIR.
I want to know how good is
ADDITIONAL INSURANCE with ExpressRMA from ncix and is it necessary(I use it in all my previous build....). And I want to know how much performance impact I will be getting for using only 2gb 6400 ram(instead of 4gb) assuming I am making him to jump on w7 bandwagon.
Thanks!
Old September 17, 2009, 06:09 PM
Kayen's Avatar
Not a bad build, very good all around performace you should expect from that machine, probably on par with mine ( in siggy ). Not sure about expressRMA, as i don't order that much, haven't encountered any RMA's .
2x AMD Gaming Builds TMan New Builds 5 August 31, 2009 02:02 PM
Hey guys, I have 3 builds, but I don't know what I should really get... feerof New Builds 11 August 12, 2009 02:02 PM
2 builds reviews Kilauea New Builds 10 May 31, 2009 07:49 PM
You Dream It, Asus Builds it, Intel Inside It! Thund3rball Mobile Computing 3 October 31, 2008 10:47 PM
Builds? CactusJoe New Builds 3 October 28, 2008 02:39 PM
