Originally Posted by Shadowmeph What about hard drives? I know in my Case I have one Hard drive properly mounted and I had to build a a mount on the case to mount a second drive |
Hard drives aren't an issue, I'm just using an old 80 Gig IDE I have kicking around for an OS drive. All the data is stored on my main rig and will be shared via a mapped drive. I will have an issue when it comes to networking up this PC, as for some retarded reason the builders installed rj45 into every room in the house (even one bathroom) but not to the family room. I'm looking into the capabilities of our wireless N setup, and if that isn't sufficient (I don't think it will be), some kind of ethernet via the power lines. But that is a topic for another thread, I think.
I've pretty much got my build finalized, and will purchase stuff tonight. Looks like I'm going with the following
Nmedia 1000B
Gigabyte GA-G31M-ES2L
Intel E5200
4 Gigs of Corsair DDR2 800
Gigabyte HD4350
Silverstone 500W
This should do fine for a $300 HTPC!
Oh, and Lowfat do you think I'll have any issues running XBMC on this?
