My last build which was quite a while ago is not in my possesion as I was forced to give it up to my younger brother. So I have a great laptop for the time being but I want to play some Far cry 2 on high again.
1. Games, and the occasional video rendering and Photoshop
2. Budget is again $3000-3500 CAD after taxes
3. Canada, Ncix
4. Intel fanboy
5. No reusable parts
6.
new gaming build slightly similar budget. But I got some questions.
7. I do plan on overclocking but no watercooling. Just a simple aftermarket HSF
8. When all the parts are available at NCIX.
Questions: :help:
1. Should I go for lga 1156 and the core i7 860 cause the mobo will be cheaper than x58? Core i7 860 has higher clock and turbo mode, and it out performs the 920 on stock settings (duh faster clock) but would it be a good overclocking processor? Better than 920? I got my old 920 to 3.8ghz on air.
2. When will the Radeon HD5870 X2 come out? Is september 10th the paper lanuch or hard lanuch of 5XXX series then the hard lanuch being in october possibly? and does it include the X2? If it doesn't should I get two 5870 in crossfire ($299 each?) I don't want to wait until Q1 2010 for the gtx 300 series.
3. Is Sata 3 worth the wait? When will Sata 3 SSD or Hard Drives come out?or will it be possible to have an extension go into a empty PCIE slot?
4. Are SSD on the verge of a price drop in the next 6 months.
5. If I got x58 is there a 6-core coming out in 2010? that I could upgrade to, even though games rarely use 4 cores
6. Should I extend my budget, would it be worth it? I can extend it to $4000-4250 max
7.Was usb 2.0 a failure? so is usb 3.0 going to be a failure aswell?
8. I am not a enthusiast just a gamer should I get a 30" monitor for 2560x1600 depending on my gpu?
9. Is it easy and trouble free to install a aftermarket cooler on my graphic cards? Does it void the warranty.
