<~----> Help for a weird build - Hardware Canucks
Old August 26, 2009, 07:45 AM
Default Help for a weird build
OK, a new problem, a new thread,
SO, this time my mother wants a new computer cuz WinXP barely runs on her P3. It seems easy, but my mother wants.... a dual boot with Win98SE. She wants it, and i can't convice her to only use WinXP.
So, is it possible to make a new build that runs win98? I think not but, your knowledge is welcome. I know I could do a VM on her new build but I've tried it and can't get her apps (win98) to work on a win98 VM.
Thanks again guys!
E8400 | Xigmatek HDT-S1283 | GA-EP45-DS3L | OCZ XTC Platinum Edition PC2-8500 4X2GB | HD 4890 1GB | Corsair Tx750W | Samsung 245BW | WD 1TB Caviar Black | Turtle Beach Ear Force X-52 | Antec Three Hundred
Old August 26, 2009, 07:59 AM
stoanee's Avatar
Try harder! This is a good excuse to build her something better!! While it is probably possible I think a new build with 98SE is an exercise in futility.
heatware
Old August 26, 2009, 08:04 AM
What applications is she running that can only be on 98???
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old August 26, 2009, 08:24 AM
I think that too but you knows, she has an old game (creature 3) that she never use and she absolutely wants to be able to run it so she will be able to not use it. The other solution is plugging two towers (one old 98 and one new xp) on the same screen using VGA and DVI port...
Old August 26, 2009, 08:30 AM
gingerbee's Avatar
no point at all. had 1 of my clients want this took me a while to convince him other wise
Old August 26, 2009, 09:14 AM
Shadowmeph's Avatar
what is the specs of your mothers computer?
windows 98se is a way better OS then xp but it is so outdated I am not even sure if you can update the security in it, what you can do is go to the black viper website and look at the services settings there and turn off all of the services she doesn't need , you could most likely get them down to 17-20 services running which should improve her performance I think that winxp needs at least 256mb ram or maybe look into either a linux Operating system or windows 2000 which is a good Operating system also.
oh and yes you can esilly make winsdows 98 run with almost any build.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old August 26, 2009, 09:38 AM
win98 runs just fine, but doesnt support usb keys, and on a newer build, doesn't support sata.
Old August 26, 2009, 09:58 AM
Shadowmeph's Avatar
sure it supports usb Windows 98 USB Mass Storage Device Drivers and having sata is kind of pointless I don't really notice any huge difference the only reason I use sata is because of the availability.
ALso there is support for sata
SATA Troubleshooter - Windows 98/Me Installation Basics | Seagate
MSFN - Microsoft Software Forum Network
Unattended and Updated Boot CD for Windows 98
Folder :
Old August 26, 2009, 10:00 AM
useless or not, an ide new build is rare, almost everything now is sata. Ive tried to make those usb key work with 98 many times, downloaded many drivers, none of them ever worked
even if they worked, she's so stubborn she wants both 98 and Xp cuz she "needs" it...
Old August 26, 2009, 10:02 AM
Shadowmeph's Avatar
I just updated my post above
Folder :
Weird Issue lcdguy Video Cards 12 July 20, 2009 08:52 AM
Weird Clicking tim333 Troubleshooting 5 May 6, 2009 07:42 PM
few weird problems with my new pc Pokeguylow Troubleshooting 5 May 6, 2009 06:21 AM
New here.. new build.. weird 4870x2 behavior. artemm Video Cards 8 March 14, 2009 05:51 PM
Weird looking devices trodas O/S's, Drivers & General Software 6 April 17, 2008 02:29 AM
