Old August 20, 2009, 06:18 PM
Originally Posted by Safearus View Post
Well, it depends on a lot of factors. Are you O/Cing your Q9550? And is that the temp at load or idle?
The Q9550 is overclocked, and its cores idle between 32 and 42 degrees. It honestly doesn't get much cooler than when not overclocked though, unless I really lower the ambient temperature - ie, opening a window in the winter.
The X2 on a cool summer night was reporting a temperature of 15 degrees. I did notice that Coretemp just reports a single temperature for the X2 instead of one for each core - is that an issue with Coretemp, or does the X2 just not report temps for each core?
Old August 21, 2009, 04:45 AM
Safearus's Avatar
Not 100% sure. I tend to check my temps via BIOS and EVEREST, so I cannot say for that program specifically.
[SIZE=2]Current Project: "i5 Rig"
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Cooler Master Hyper 212 EVO
Motherboard: Asus ROG MAXIMUS VIII HERO ALPHA
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200
Storage: Samsung 850 EVO 250GB M.2-2280
Storage: Seagate Barracuda 1TB 3.5" 7200RPM
Video Card: Asus GeForce GTX 1060 6GB Strix
Case: Fractal Design Define R4 w/Window
Power Supply: Silverstone Strider Gold S 850W
Bioshock 2: Big Sister is Waiting! Thund3rball Gaming 170 March 26, 2010 03:16 PM
Need Uni Notebook for Sister ~$600 bovine.baron Mobile Computing 3 June 1, 2009 11:57 AM
NCIX gift card at a sister company? CMetaphor Off Topic 9 May 20, 2009 10:32 AM
Cheap Gamer/Websurfer for Sister. ImmaPC New Builds 5 January 10, 2009 08:31 PM
$500 PC For Sister geokilla New Builds 12 August 15, 2008 12:20 PM
