Old August 17, 2009, 10:16 PM
kaufman37's Avatar
Default Help me finalize my 1st build #2
Ok i have done some reading and heres my new plan
MB: ASUS Rampage II Extreme X58 :: $500 CAD
RAM: 3x 2GB DDR3 G-skill :: $200 CAD
COOLING: Thermaltake Bigwater SE +Motorsports Radiator & P500 WATER PUMP :: OWNED
DVD DRIVE: liteon super allwrite drive :: OWNED
CASE: CoolerMaster HAF 932 :: OWNED
CPU: Intel Core i7 920 I7-920 2.66GHz :: $300 CAD
GPU: 3x XFX GTX275 :: $900 CAD
PSU: Thermaltake Toughpower 1200w :: $300 CAD
HD: 2x 1TB WD GREEN :: OWNED
This is not realy a budget rig but i do want some value so what do you think?
Old August 17, 2009, 10:27 PM
Infiniti's Avatar
In my opinion, everything looks good, but I would get some new hard drives. The Greens will seriously bottleneck your gaming performance, and that's a no-no. Maybe get some Caviar Blacks and RAID them, while using your Greens as storage?
Old August 17, 2009, 10:33 PM
kaufman37's Avatar
what if i got like a raptor or something like that?
Old August 17, 2009, 10:36 PM
Infiniti's Avatar
Waste of money. I doubt you'll notice much of a performance difference from 2 WD Blacks in RAID 0 compared to a low capacity Raptor. They'll cost roughly the same too.
Old August 17, 2009, 10:46 PM
kaufman37's Avatar
well the only reson i got the WD greens is thay we'r $50 CAD anyway why should i get 2 wd blacks? i don't know a whole lot about raid only what i have read last pc i worked on was befor sata
Old August 17, 2009, 10:53 PM
CroSsFiRe2009's Avatar
If it's value your looking for, go for a cheaper mobo, you can easily save at least $200 there. Unless your folding, go with 2 275's instead is my opinion, tri-sli isn't worth it atm. Grab a ssd while your at it and drop the psu to a 1kw model if your that intent on the power. You can save a bit going with the Corsair 1kw model or something. Not too sure on the psu's but you can definitely go a bit easier on the wattage.
Old August 17, 2009, 10:54 PM
Oh and can you keep your thing to one thread? Just reedit your original post instead of starting a new thread
Old August 17, 2009, 10:56 PM
CanadaRox's Avatar
I'm not sure how well that loop will cool the CPU. ThermalTake is pretty well known in the water cooling loop (ha ha) as making some pretty lame products that aren't up to par with the rest of the companies.
Project: Black and White
Old August 17, 2009, 11:12 PM
kaufman37's Avatar
Whats so wrong with ThermalTake watercooling? I know it's a bit old but i added a new 120mm x2 Radiator and a pump it now has a total of 120mm x 3 for Radiators and 2 pumps a waterblock what more do the other companys have?I ready have this setup if it would keep it cool to overclock it would be great but im not sure. maybe i should just keep buying Radiators till i can't fit anymore.....
Old August 18, 2009, 08:08 AM
martin_metal_88's Avatar
IMO I would drop the rampage and get more complete board from any other company for like half the price XD. Go with the GA-X58-UD5. You have more sata much better lay-out for PCI and PCI-e port like 150$ cheaper ( wich you can put on a SSD for windows :O more USB and more of everything. IMO for the rampage you paid 500 only because it's asus like a classified. That would be a killer rig;)
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Help my finalize my 1st build kaufman37 New Builds 20 August 18, 2009 11:10 PM
Help me Finalize my 1st Build kaufman37 New Builds 8 August 9, 2009 10:45 AM
Just finished my 1st build Dogger1 New Builds 21 February 12, 2009 09:38 AM
1st Post, new build, what do you think? Cowinacape New Builds 16 July 31, 2008 09:05 PM
Stuck on my 1st build Mr. Cipher Troubleshooting 9 November 2, 2007 01:36 PM
