Old August 13, 2009, 07:12 AM
Smile Planning to build i7 RIG, Need advice!
Hi,
I'm still new to the forums but i am pretty experienced in computers (going for the A+ in 2 weeks).
I am planning on building a new i7 rig.
1. It will be used mainly for gaming, homework, music, email, movies, and other small tasks.
2. $3000-$3500 CAD
3. Buying parts from CANADA (TORONTO)
4. Brand, Intel Core i7, and nVidia GTX 280+ (Buying 2 for dual sli)
5. Not planning on using any current parts.
6. I have researched and i have a few questions which i will post under this.
7. Planning to build in 1-2 weeks.
Okay,
so my specs are:
Case: Thermaltake VH6000BWS Armor+
Mobo: EVGA x58 Classified mobo
CPU: Intel i7 920
Video Cards: EVGA GTX 280 (2 of them for dual SLI)
RAM: OCZ 2000 Mhz 6GB RAM
HDD: Seagate 1GB
Cooling: Swift tech H20 Apix Ultima
Speakers: Logitech X530 5.1 surround sound
Headset: Tritton AXPRO 5.1
Sound Card: Creative Labs X-fi Fatalty Xtreme Gamer
So, that is going to be my rig.
NOTE: I won't be overclocking TOO much, that is why i am asking for some advice.
Is this rig good enough for my needs or do i have too much that i don't need.
I know the Core i9 and GT 300 is coming out in Q1 2010 but i don't know if i have enough money for that.
I need to know if there is something i should replace.
Thanks alot
Old August 13, 2009, 07:39 AM
Sodium Bromate's Avatar
Seriously? Your budget is 3.5k and you don't think you'll have enough? You will, trust me.
Anyway, here are my thoughts.
Case: Thermaltake doesn't make quality cases. I suggest Lian-Li or Coolermaster.
Mobo: The board you chose is certainly a good board, but a bit overkill. Up to you.
HDD: I think you meant 1TB? And I'd go with WD instead of Seagate.
Sound Card: You'd be better off with an Asus Xonar DX.
Other than that it's pretty good.
Have fun building!
Old August 13, 2009, 07:54 AM
Have fun building!
O yes, 1 TB hehe
How much will the new processors and new GT 300 series graphics cards cost?
Because 3.5K includes shippings and taxes
Old August 13, 2009, 07:57 AM
No price range is set, but I can pretty much guarantee that with that budget, you'll be able to get one. Build the computer, use those specs, and use your current graphics card until the new series is out. With the money left over from your budget, you'll definitely be able to buy a 300 series card.
Old August 13, 2009, 08:10 AM
My current graphics card is completely bogus...a GeForce 6150
Old August 13, 2009, 08:35 AM
Arinoth's Avatar
If your going gaming and have the larger budget, i think you should get at least 1 SSD seeing as you'll get even better performance for your hdd that way, you can decide if you want just a small one for your OS, or a larger one for your OS and games
Old August 13, 2009, 08:38 AM
bojangles's Avatar
Are you getting water cooling for just the looks I assume, since you said you won't be overclocking much? I wouldn't get water cooling gear unless you want to push your computer to its limits.
Thermaltake makes some pretty crappy cases, and while the one you mentioned is quite large, it sucks. Get an ATCS or HAF 932 or something that really spells performance.
There is no point getting the EVGA X58 Classified unless you either want to overclock to the limit or have it for eye candy. There's boards half the price that will get the same performance out of it.
The GTX 280 is old tech. Get a pair of GTX 285s or 275s if you really want something newer.
Definitely go for either Western Digital Caviar Blacks or Seagate's 7200.12s. Both of those are great models and have plenty of speed. However, with your budget, why not go for an SSD for the OS and a nice 1 TB drive for data?
Everything else is cool. I really wouldn't both waiting for the new tech coming out. Heck we can't even hit the limits of today's tech right now. It's more than fast enough.
Old August 13, 2009, 09:06 AM
Is a 850W Power supply enough or do i need a 1000 PS?
Also, What does the Solid State Hard Drive do? I mean, why is it so expensive? And why is it good for me to use that for my OS?
Old August 13, 2009, 09:15 AM
Arinoth's Avatar
+1 on what bojangles is saying
Solid State Hard Drives are basically flash memory in higher storage capacity, so they have access, read/write times that are miles faster/better then a regular hard drive. The reason you'd want this for your OS is the fact it will speed booting up, as well as increase overall performance and response of OS as well.
Old August 13, 2009, 09:17 AM
How big of a SSD would i need?
Planning a new build? Need a x64 bit OS? I have a DVD copy of Win 7 to give away! Triggz New Builds 12 March 22, 2009 03:17 PM
Planning on overclocking Q6600 soon, need a little advice Matt Overclocking, Tweaking and Benchmarking 25 January 26, 2009 12:19 PM
New Rig Advice darren700 New Builds 10 October 30, 2008 02:55 PM
Planning on a new build Jo5h New Builds 7 October 14, 2008 12:10 PM
Compact Watercooled Gaming Rig! (planning stages) Cptn Vortex Case Mods, Worklog & Gallery 9 January 11, 2008 08:57 PM
