Old August 9, 2009, 11:04 AM
Default Help Designing a case
I am thinking About designing a SFF case for myself because i cannot find one i like. My problem is that i cannot find the exact dimensions of the rear i/o panel and expansion slot sizes. If any one can help me with those dimensions it would be greatly appreciated.
My design is i was gonna build it like the lian-li PC-A05N in orientation but with 2 fans along the bottom of the case kind like new RV02 or FT02, ether the antec big boy or the coolmaster stormforce 200mm and it is gonna fit a IFX-14 in there. but i dont know if i should put the PSU like the NZXT PANZERBOX or in the front like the lain-li but facing up to shorten the case. any feed back is welcome will post some renderings when i can
Old August 9, 2009, 01:57 PM
My first Go at a design
Old August 9, 2009, 02:04 PM
jcmaz's Avatar
I don't get why you would put 2 fans on the bottom. How are they suppose to get air? Many ppl like their PSU on the bottom b/c it gives the tower stability.
-Plato
Old August 9, 2009, 02:34 PM
i put the fans down there because heat rises and the case will have feet on it and will still have the normal 120 on the back i just suck at autocad
heres a nice case with Bottom mount fans
http://silverstone-usa.com/images/RV02/RV02_2s.jpg
Old August 9, 2009, 03:45 PM
Sushi Warrior's Avatar
Use SketchUp if AutoCAD is too hard. I would say make 1 big fan at the top and one at the bottom and just have a big path of airflow, but I guess the GFX card would mess that up.
Need help designing a loop Cowboy Water Cooling 8 May 29, 2009 04:01 PM
A+ Case Black Pearl WCR Edition ATX Case Babrbarossa Reviews & Articles from the Web 0 June 19, 2007 09:28 AM
