Finally going to take the i7 plunge. Even though I am not sure I really need it as my Q6600 is fine, the urge to go i7 won't go away. Will get a few extra PPD on vmware with an i7
I am upgrading my current setup by replacing the mobo, cpu, ram, and hsf only. The old parts will be placed in my folding rig in my sig. Here is my current parts list copied from my sig:
Q6600 G0@3.0GHZ, Mushkin HP PC2 6400 4-4-4-15 4GB, Gigabyte EP35-DS3P, 2 X EVGA GTX 285, 2X WD Raptor Raid 0, Enermax Revolution85+ 1050W, CM HAF 932, LG Blu-Ray GGC-H20L, Hauppauge HVR-1600 Tuner
Will be looking for a D0 i7 920, and hoping to get ~3.2ghz on air, which seems to be no problem.
Here are the things I considered for the upgrade, in order of importance:
- Two PCI-E 16x slots. When both slots are populated, a PCI slot needs to be available for my Tuner card which is PCI. Don't care about Crossfire or SLI really, as I use two cards primarily for folding and not gaming.
- Onboard sound. I am open to using onboard sound, but wouldn't mind pay a little extra for a mobo if the onboard sound was better than another solution. From what I can see, there is little difference in the current solutions. Perhaps someone can make a suggestion here.
- Cost. Hoping to keep this below $800 before taxes. As always, in fits of madness I sometimes blow the budget.
- Brand. I currently like my Gigabyte board, and have had two bad experiences with Asus boards the last two purchases I made. I am leaning toward Gigabyte again for this reason, but could be talked into something that really seems to be better or more reliable.
- Ram. Looking for DDR3 1600, but I am not sure I will need that much headroom for the OC I will do. Must keep ram at 1.65v. I also hope to avoid the huge ram heatsinks (like the Dominators or Reaper).
That's mostly it. Here are the parts I am thinking about so far:
- Gigabyte GA-EX58-UD3R, $229.99, Canada Computers - Motherboards > Socket LGA1366 : Gigabyte GA-EX58-UD3R Socket 1366 Intel X58 + ICH10R CrossfireX Triple-Channel DDR3 2000+/1333/1066Mhz Dual GigaLAN 7.1Ch Audio 6x SATA 2x PCI-E X16 . Hoping to get the new 1.6 version. The new revision has slightly better (official) OC support, and a larger bios chip (16mb vs 8mb on regular version). Not sure I need either, but I am thinking that the newer revision might have some other under the hood improvements.
- i7 920, $344.99, Canada Computers - CPU > Desktop Intel Processors : Intel Core i7 920 Quad-Core Socket LGA1366, 2.66Ghz, 4.8GT/s FSB, 8MB L3 Cache, 45nm (Retail Boxed) (BX80601920).
Going after the D0 version of the chip, which is marked SLBEJ. If someone is selling a D0 I will be willing to pick that up. - Mushkin XP3-12800 DDR3-1600MHZ 6GB, XP Series Cas 7-8-7-20 (1.65V), $164.99, Canada Computers - Memory > Desktop Memory > DDR3 1600 PC3-12800+ : Mushkin XP3-12800 DDR3-1600MHZ 6GB (3x2GB) Triple Channel Kit XP Series Cas 7-8-7-20 (1.65V) 240pins (998679).
Liked this ram as my current Mushkins have been good, the price is OK, and the timings seem up to par. - Cooler Master Hyper 212 HSF, $43.99, Canada Computers - Cooling > CPU Cooling : Cooler Master Hyper 212 4 Heat Pipes, Copper Base (RR-CCH-LB12-GP) for Socket LGA775 & AM2/754/940/939.
Seems like a great HSF, as good as the TRUE which was on my list first until AkG's 212 review here.
That's it. I stuck to Canada Computers as they are local, but I could go with something at
Infonec. I don't wish to purchase online.
Open to suggestions if I have missed something. Stability at ~3.2GHZ is what I al looking for, and I don't need too many bells and whistles on the mobo. I am willing to pay a little more (~$300) if there is a truly great mobo at Canada Computers or Infonec that will suit my needs.
Thanks guys! This will be folding 24/7 so stability is paramount. Heat is an issue too (but not going water).
