Hey HWC
I decided to make another thread b/c the other one was in a bad section. Anyways, which fan from the bottom should i get? It is for exhaust fan. If you don't like them, plz give some suggestions, but they have to be under $10.
GELID Solutions GELID Silent 12TC 750-1500RPM 120MM Thermal Control Fan 58CFM 12-25.5DBA HDB 3PIN
Special Features: $7.99
Has a special sensor for measuring the temperature.
Quiet and lots of CFM
white!!!
Rubber gromets
----OR----
Yate Loon D12BL-12-UB 120MM UV Blue LED Fan 1200RPM 45CFM 24DB 3/4PIN Ball Bearing Sleeved Retail
Special Features: $8.99
Blue LEDS lights!!!
Quiet but not as much as the Gelid
Apparently its somewhat of a cheap plastic
