<~----> HTPC system - Hardware Canucks
Old July 22, 2009, 02:08 PM
martin_metal_88's Avatar
Default HTPC system
Hey guys, I'm concidering to build a new HTPC around my DP45SG + my G.skill DDR3, I don't really know what part I want to get but cross-fire would be a cool way. I also can get a Antec TRIO 430 for cheap ( old PSU of my sister boyfriend ). What would you suggest me to go with for cheap but good. I know that I can find the part by myself but there is always good idea here so now it`s your turn guys:P
The case would also be a Silverstone lascala 17 or any other that I can fit a ATX PSU and normal piece inside ( any full ATX board for fitting my DP45SG )
Ask if more info needed
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old July 22, 2009, 02:13 PM
Arinoth's Avatar
Using cross-fire in an HTPC would seem like a rather large waste not to mention i dont think that PSU would be apply to supply enough power, so to avoid head aches or prolbmes i'd say to ignore that part of your idea
HTPC Help Burkdaddy New Builds 8 July 23, 2009 06:14 AM
Is linux a good choice for an HTPC system? quikgp HTPC Systems & Software 6 April 28, 2009 06:17 PM
good operating system for HTPC? quikgp HTPC Systems & Software 9 April 28, 2009 01:10 PM
HTPC OS? biff HTPC Systems & Software 25 February 26, 2009 06:09 PM
My HTPC. TopDogZero Case Mods, Worklog & Gallery 1 May 14, 2008 04:53 AM
