I agree with jcmaz, get the seasonic or corsair, more reliable and in those cramped confines, I'll take the reliability of those 2 psu's over the ocz even though it has modular cables. As for whether or not it's enough, it's pushing it nearly to its max but if you want a definite yes or no whether it'll run, yes. My only issue with the build is the G41 mobo, been browsin over on [H] and seems like the Gigabyte G31M-S2L is one of the best OC'ers ever along with it being a cheap motherboard so you might want to consider that instead of the current one.
Also, I believe the AC Freezer Pro won't fit. Your going to have to get a LP cooler such as a Scythe Shuriken or a AC Freezer LP
