Old July 21, 2009, 02:16 PM
jcmaz's Avatar
Default Build or Wait???
Hi,
My brother's birthday is coming up and i want to upgrade his 1.73 GHz Core 2 Duo laptop to an AMD system. The problem is should i wait til the middle/end of August for the new AMD parts or take advantage of the prices right now and build a new comp. Our budget is about $300-$400 including videocard
what we've come up w/ so far:
Have: 8500GT (but i want to sell it)
OCZ Vista Upgrade PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-15 240PIN DIMM Dual Channel Memory Kit
Some Samsung DVD drive
a Gigabyte mobo for sure coz i don't like Asus' website and their updates
- i was looking at their 780G mobo or the 770 ones
processor
- AMD for sure but i'm not sure which one. ~$110 budget
case: i'll buy that from HWC :)
HD: preferably WD
-Plato
Old July 21, 2009, 03:30 PM
bkh2's Avatar
Parts that have just come out are usually overpriced, so I'm not sure if waiting for the new stuff (with intent to buy it) is a good idea, especially if you're on a budget. But if you wait, the setup you are planning to build right now will probably be even cheaper.
Old July 21, 2009, 03:53 PM
jcmaz's Avatar
wats the info on the next gen mobos???
-Plato
Old July 21, 2009, 03:56 PM
Silvgearx's Avatar
AMD eh.
for HTPC board a 785G is coming and it shown at the US newegg site. should be here any moment now. someone saw it been sold for $95 USD
If your going 790 chipsest get it now :P the next gen amd chipset won't be here till 2010 Q1 or Q2 or it might be even later :(
Old July 21, 2009, 09:14 PM
JD JD is offline
AMD Athlon II X2 250
Gigabyte GA-MA770-UD3
OCZ Vista Upgrade 4GB (2 x 2GB) DDR2 800Dual Channel Kit
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA
SAPPHIRE 100253DDR3L Radeon HD 4650 512MB 128-bit GDDR3 (GDDR3 HD4650, so I'd assume it performs a fair bit better than the typical GDDR2 ones)
Total: $337.96 + case, DVD-RW
And what about a PSU? That might be pushing your budget if you need one.
Old July 22, 2009, 07:54 AM
jcmaz's Avatar
thanks jdrom
but i only need 2 gigs of ram i think i'll give my 9600GT to my brother. I might just get one of those Seasonic 400W or Corsair 400W PSUs.
-Plato
Old July 22, 2009, 09:12 AM
JD JD is offline
Originally Posted by jcmaz View Post
thanks jdrom
Well since DDR2 is rather cheap, and it doesn't cost significantly more, I don't see a reason not to get 4GB. Choice is yours though.
Another PSU option would be the OCZ StealthXStream 500W. They're fairly cheap, and even more so after the $30 MIR.
And you know, his PC will be better than yours
Buy now or wait? Hermesˇ˘ New Builds 9 December 22, 2008 11:26 PM
Upgrade now or wait for Nehalem? Infiniti Off Topic 9 October 16, 2008 09:30 PM
Can't wait till I can do this.. Wheee!!! Bognostraglum Off Topic 1 August 11, 2008 12:46 PM
finally but WaiT HELP Rapid-X Troubleshooting 2 August 9, 2008 06:41 PM
New Mobo ordered!!!! Can't wait!!!! :) sswilson CPU's and Motherboards 68 June 1, 2007 10:06 PM
