  #31 (permalink)
Old July 25, 2009, 04:11 PM
bkh2's Avatar
Update on my water cooling: It's leaking more than Rapture....
Testing it outside the case at the moment, fortunately XD
Hopefully I can get this into my case soon....
Thanks for all the help guys. Nice build you got there, jdrom17. =]
EDIT:
^ Testing the loop before installation. ^
Second pic shows the hole I made so I could do some wire management. Duct tape for the win... Hopefully this is temporary. I'll get a new case when I have the money to invest in it.
  #32 (permalink)
Old July 25, 2009, 08:02 PM
JD JD is offline
I suggest buying proper, metal barbs. No idea what you're using right now exactly, but it doesn't that brass one definitely doesn't look right.
New to water cooling SquattingDawg Water Cooling 30 July 12, 2009 03:40 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
