Old July 18, 2009, 02:14 PM
Default What is currently the best bang for the buck system?
Title sums it up, what is the current best bang for the buck system right now?
Old July 18, 2009, 02:23 PM
Arinoth's Avatar
Really depends on what your using the system for as each fall into different categories.
Is it for web surfing/office use
Is it for low end gaming
Is it for high end gaming
Is it for low end folding
Is it for high end folding
Best bang for the buck is all relative to what the system is going to be primarily used by those using it
Here I am: here I remain
Old July 18, 2009, 02:34 PM
Oh, sorry. Best bang for the buck gaming system.
Old July 18, 2009, 02:45 PM
Arinoth's Avatar
Which then leads to what kind of gaming, video graphics settings (low,mid, mid-high, high, extreme), preferred resolution to run the games at.
As an example i typically have my games (current example is Fallout 3) at high graphics settings at 1920 x 1080 with the rig in my sig.
Old July 18, 2009, 02:54 PM
Why would that be a question? I'm just asking in terms of fps/$ regardless of settings.
Old July 18, 2009, 02:56 PM
Right now, since I've sold my old quad-core to buy my '79 z28, I'm on a 7950GT, with a 4200+. It's quite old, and is just squeaking by on low settings with newer games. I'd just like a newer system to play games with, but have the most value for my dollar sort of thing.
Old July 18, 2009, 03:10 PM
rapmaster's Avatar
what resolution are you playing at and what is your budget?
Quando omni flunkus moritati
Old July 18, 2009, 03:14 PM
Well, I sold my 22", so I'm on a pitiful 19" 1440x900 screen.
There is no budget.
Old July 18, 2009, 03:17 PM
Babrbarossa's Avatar
NCIX.com - Buy ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard - P5Q Pro In Canada. - $130
NCIX.com - Buy G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel Memory Kit - F2-8500CL5D-4GBPK In Canada. - $60
NCIX.com - Buy Samsung SH-S223Q/BEBS 22X DVD+-RW SATA DVD Writer Black Lightscribe OEM - SH-S223Q/BEBS In Canada. - $30
NCIX.com - Buy Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - HDT-S1283 In Canada. -$30
NCIX.com - Buy Antec Sonata III Black ATX 16IN Mid Tower Quiet Case 3X5.25 2X3.5 4X3.5IN 500W 120MM Fan - SONATA III 500 In Canada. -$120
NCIX.com - Buy Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - WD6401AALS In Canada. Digital WD&promoid=1190 -$80
NCIX.com - Buy Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail - BX80570E8400 In Canada. -$195
NCIX.com - Buy EVGA E-GEFORCE GTX 260 Core 216 55NM 576MHZ 896MB 1.998GHZ GDDR3 PCI-E 2XDVI-I HDTV Out Video Card - 896-P3-1255-AR In Canada. -$185
For a total of about $830
This system will overclock very well too if you invest in a good PSU for a little extra- if so, go for a cheap case without a PSU and buy a ~550w-650w corsair
EDIT: doesn't sound like this is in your snack bracket...
Old July 18, 2009, 03:21 PM
Very nice, however, isn't AMD king of the bang for the buck right now?
Bang for the buck Overclocker Alwaysrun Case Mods, Worklog & Gallery 36 May 7, 2009 09:31 AM
Motherboard - Best bang for the buck element291 CPU's and Motherboards 18 January 6, 2009 08:33 PM
Best bang for your buck Hard Drives. Sniper Storage 13 December 3, 2008 08:45 AM
$1000 Bang for my buck Overclocker Alwaysrun New Builds 25 September 25, 2008 12:32 PM
Bang for the buck g10 New Builds 8 August 13, 2008 11:19 AM
