Old July 10, 2009, 10:47 AM
CMetaphor's Avatar
Quadfather
Default Project: Dark Hybrid
Okay, im tired of keeping secrets and want opinions on the build anyways, so here goes:
Components:
?????, passively cooled by a CM GeminII (for now, possibly the new Scythe Shuriken later)
4Gb G.Skill Ram. - already have.
Enermax Modu82+ 525w PSU
2x Arctic cooling 12025 PWM sharing fans
Silverstone SG-03 mATX case
Video card: ???? See my WTB page
Have you guessed it yet? Yep - I'm going to try out a Hybrid power build. For those that don't know what I'm talking about (and thats possible considering Nvidia never advertised the feature and has since NERF'd the feature out of its recent graphics cards) - its the ability for an Nvidia chipset based motherboard to completely turn-off its discrete graphics card and revert to the onboard when switched in Vista (and hopefully Windows 7 - ill be trying 7 first).
The problem? 55nm Graphics cards have all been stripped of this feature, and even if it is on a supported card, it might not be implemented by the manufacturer, so I have to check each cards specification individually before trying to buy it. At best, so far, I was able to find a new XFX 9800GTX+ from newegg.ca that supports it, but its expensive for an older card $160 and not quite as powerful as I'd like.
As you can probably guess, the whole idea of the system will be to be extremely power efficient for 2D, then turn on the 3D graphics for gaming only. "Dark Hybrid" is named as such for the Hybrid power feature it will use, and the fact that at least so far, ALL the components are black aka dark.
Thoughts?
Old July 10, 2009, 11:13 AM
CMetaphor's Avatar
Quadfather
Ha ha... cats out of the bag and no one cares Yay me! lol... /joking
Old July 10, 2009, 11:31 AM
Soultribunal's Avatar
Asus VC's have some feature built like that right on the card. Their Matrix series at least.
My Card when not doing anything will power everything down including the Dual Cooling Fans.
Check out them and see if they have the VC for you CM.
And, get an X2 550 and board :P
ST
Old July 10, 2009, 11:38 AM
CMetaphor's Avatar
Quadfather
LOL. I would've loved to have made this build an AMD one ST, trust me. However, the ONLY motherboard that I can find with M780G chipset is the MSI Media Live board, which doesnt support ATI's equivalent to Hybrid power (even though according to AMD, the m780G can support it - MSI just didnt want to). Trust me, i did my research .
I'll check out some Asus cards and see what i can find.
Old July 10, 2009, 11:46 AM
Supergrover's Avatar
NCIX.com - Buy EVGA E-GEFORCE 9800GT 55NM 600MHZ 512MB 1.8GHZ 256BIT GDDR3 Dual DVI-I HDCP HDTV Out Video Card - 512-P3-N973-TR In Canada.
But it is probably not powerful enough for you, I looked into this last year but never followed through with it, I thought the hybrid feature would work well for my HTPC build and still play a few games on it.
Interested in how it does end up working for you.
R.I.P.
Old July 10, 2009, 11:48 AM
CMetaphor's Avatar
Quadfather
Hey supergrover, as I mentioned, Im pretty sure all the 55nm versions of nvidia graphics cards have been stripped of the hybrid power feature. I'll check to make sure, but I've yet to see anyone do this with success on a 55nm card. Thank tho!
Old July 10, 2009, 11:54 AM
rjbarker's Avatar
Very cool...I have read this Hybrid Feature you're referring to...
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old July 10, 2009, 11:58 AM
CMetaphor's Avatar
Quadfather
Thanks. Looking like it's vista-only for the time being. I hope that changes in the near-future otherwise nvidia's going to have some angry laptop customers who's discrete graphics cards wont turn on/off at all (except via bios).
Old July 10, 2009, 12:12 PM
CMetaphor's Avatar
Quadfather
Asus: Has pulled all their 260-series cards from their canadian website? How helpful. Im really looking at a gtx280 now, even though it'll be tough on the smallish 525w PSU, the 82+ % efficieny should make up for it .
Old July 10, 2009, 12:15 PM
eVGA - EVGA E-GEFORCE 9800GT Hybrid Single Slot 512MB 600MHZ 256BIT 1.8GHZ... - 512P3N980AR - Powered by PriceCanada.com
My bad CM HC search listed a 512P3N980AR but when I linked to ncix it shows up as a 512-P3-N973-TR 55mm.
R.I.P.
Acom Data Photon Portable Hybrid Drive Software 3 of 7 Storage 0 November 15, 2008 01:57 PM
(PR) NVIDIA Intros Hybrid SLI Technology Hardware Canucks Video Cards 7 May 6, 2008 03:48 PM
Hybrid graphics mhbrown41 Video Cards 5 March 21, 2008 05:00 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
AMD previews Hybrid CrossFire Shadowmeph Press Releases & Tech News 1 December 14, 2007 06:01 PM
