Old July 9, 2009, 08:45 PM
Fox's Avatar
Fox Fox is offline
Default Building for a friend ~$1100
Hi all, I'm looking for some help in building a computer for my friend. My buddy has about $1000-$1100 or so for a build, and here is what I was thinking about. It will most likely be for games with maybe a little graphics work.
Motherboard:
ASUS P5Q Pro ATX - $129.88 - DirectCanada
CPU
Intel Q9550 - $249.99 - Newegg
RAM
G.SKILL PI Black 2x2GB - $56.79 - Best Direct
Video Card
XFX HD 4890 - $227.99 - Newegg
Power Supply
Corsair 550W - ~$75 ($98.49) - Newegg
HDD
WD Caviar Black 640GB - $77.99 - NCIX
Monitor
Acer X223WBD Black 22IN - $192.76 - NCIX
Case
NZXT Beta Series - $59.99 - Newegg
Total w/ Tax & Rebates $1203.24
It's still a little over what he is looking to spend so I was wondering if there are recommendations for parts that are a little cheaper to cut the cost down. I was originally going E8400 instead, but for $60ish I was thinking the Q9550 would be worth it.
Additionally, he's isn't particularly a fan of AMD, but if It turns out they have better price performance, he could probably be swayed. Although I don't see the huge benifit to going the 940/945/955 route as the 945 is the same cost as the Q9550 and seems to be worse then the Q9550.
Thanks in advance for your input. And incase your wondering, I don't post much, but I lurk a lot and fold for the team under Trotts.
Old July 9, 2009, 09:01 PM
He will surely need a DVD drive too, perhaps an o/s, keyboard, mouse ?
As far as AMD is concerned, I can't complain a bit about my 940 and you can get some combo deals which include mobos and 940 for 300$, that would make him save 80$.
If I were you, I'd look for deals on that card, its a great one. I personally got mine about a month ago for 199 and last week end(I think), there was an awesome in store special with very limited quantities for this same card for (I forgot) between 150-160 at NCIX. I wouldn't be surprised to see some other deals like that.
Also, I suggest you just buy it all from NCIX and PM.
Old July 9, 2009, 09:18 PM
chouchou's Avatar
Yup, agreed with the NCIX point. Don't forget you have to pay seperate shipping charges etc...
Old July 9, 2009, 09:24 PM
if you buy the mobo at NCIX ,you get free shipping on entire order NCIX.com - Buy ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard - P5Q Pro In Canada.
PM the rest for best deal
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old July 9, 2009, 10:53 PM
Fox's Avatar
Fox Fox is offline
As far as a keyboard/mouse and DVD-rom goes, I plan to buy them during a NCIX special probably just a cheap logitech keyboard and cheap DVD drive. As for OS I'm probably going to load on Windows 7 RC. Also, I live about 20 minutes away from NCIX so I was planning on PM'ing everything and picking it up in store.
As for the 940, it almost seems smarter to get the 945 for a little more to make your system a little more future proof with the AM3 socket. Although, I guess the same could be said for going to 775 route with the Q9550.
Has anyone had any experience with the X3 720, I was thinking possible getting a relatively cheap motherboard/CPU/ram and waiting for 6-12 months for prices to drop further on i7/i5 and the amd releases. If you bought a decent card, PS and HDD, case and monitor, you could keep those when you upgrade later.
As far as gaming goes, with a decent card, the X3 720 would be able to provide enough power so the bottlenecking would occur due to the graphics card right?
Also, in the price range of ~$220 do you think the 4950 is the best price/performace or would looking for GTX 275's on sale be a better option? I personally use a GTX 260 which works great for me, personally I like Nvidia better, but it seems with the 4950's ATI is hard to beat.
Thanks again.
Old July 10, 2009, 11:55 AM
Thanks again.
The x3 720, would definitely act as a bottleneck still. It simply not a fast processor. In games like farcry 2 and gta4, which are cpu limited, your going to have kind of bad performance. GPU limited games you are going to miss out on about 15-25% of the frame you could get.
Old July 14, 2009, 10:27 PM
Heres my suggestion :): Intel Core 2 Duo E8500 Wolfdale 3.16GHz -$238.09Asus p5q-e Motherboard - $174.99G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 1066 - $60.00XFX GeForce GTX 285 1GB - $399.99Western Digital Caviar black 500gb 7200rpm - $79.46Samsung SH-S223f - $32.99OCZ StealthXStream OCZ600SXS 600W - $99.99COOLER MASTER Elite RC-31 - $45.99Grand total of = $1131.5 CAD
Old July 14, 2009, 10:31 PM
Oh and for the list i posted above... those are all the prices that are listed on ncix with no price match or rebates included...so shop around and look around and find the lowest price you can and do a price match, cuz that could save you alot of money... and you could always cheap out on the graphics card and get a gtx 260 instead and go with a quad core...but if your friend can save up like $1400 he could probably make a decent i7 rig :)
Logitech MX Revolution or the MX 1100? AERo Peripherals 14 May 23, 2011 11:13 PM
Build for a friend lanken123 New Builds 5 May 6, 2009 08:54 PM
Find that old Dell s: 1100, 1150, 5100, 5150. Class Action suit looks good. Mark Press Releases & Tech News 4 March 11, 2009 04:25 PM
Build 4 a Friend. BALISTX New Builds 5 June 25, 2008 01:21 PM
New comp for a friend. belgolas CPU's and Motherboards 7 March 12, 2008 08:04 PM
