Old July 7, 2009, 06:43 PM
Default Need suggestions on new PC build
The first thing I have to say is, WOW there is so much information here that it got me overwhelmed.
I am looking on building a PC in the next 1 1/2 months and read a lot of information on the forum. Since there is just such a huge wealth of information out there and this is my first PC build in roughly 3-4 years it got me quite confused. I would appreciate any help you guys/girls can give me in building a PC for my use.
In regards to spending cash, I am looking to spend between $1200-$1500 on this system with hopes to include 1-2 monitors.
Primarily I'll be using this system for office use, as well as graphics/multimedia and some gaming (when no one is looking).
Due to me having to always multi-task when it comes to documents and graphics/multimedia I am looking for a strong CPU (wouldn't mind trying the i7) and lots of memory.
At this time - as I am not familiar to much with overclocking - there is no strong emphasis laid on it, neither is there on what brand things are... oh before I forget, since my last build was over 3-4 years ago I won't be reusing any parts - 100% from scratch.
Look forward to suggestions and if you got questions please ask me I'll do my best to reply.
Thanks!
Mark
Old July 9, 2009, 07:28 PM
...bump
Anyone got any suggestions? I would really appreciate it.
Thank you!
Old July 9, 2009, 07:36 PM
Silvgearx's Avatar
lets get you started
Judging from your budget you'll likely to get dual 20"-22" LCD monitors
What games and what kinda muti-task?
Any brand preferences?
Usable old parts?
Overclock?
Canada?
Old July 9, 2009, 08:06 PM
Usable old parts?
Overclock?
Canada?
I think the monitor size would be good, any bigger than that and you might as well buy a TV .
In regards to games, games like the new Batman game, Assassins Creed 2, Sims 3, Fallout 3, The Civilization games, those would be a few that come to mind.
The primary function would be, graphics, editing and creating them. I use a lot analysis tools in addition to the graphics as they go hand in hand when planning for marketing strategies and then implement them by creating logos, letterheads, brochures, magazines etc.
Brand preference... honestly no, but from my understanding the i7 supposedly is the quickest and if that would fit in the budget why not, more power is always appreciate.
No usable parts, a build from scratch.
Overclocking? Always welcome. I am somewhat of a novice in that field but if time invested in it justifies the gain, hey it's welcome.
Thanks again for taking the time to help out, and I hope this gives you some ideas what it would be used for.
Old July 10, 2009, 05:10 PM
Silvgearx's Avatar
Its just a general idea of what you can get.
You can probably lower the price by $200+ if you do a proper price research and price match at NCIX.
so you have around $400 left to spend on monitor before price research.
If you want AMD just switch out the CPU and mother board to a phenom II 940 @3.0ghz + a 790gx/x chipset
ohh i left out the $20 dollar DVD drive
Old July 14, 2009, 09:01 PM
Thank you for your input, I'll definitely look into that setup.
Old July 14, 2009, 09:24 PM
stoanee's Avatar
Intel Core I7 920 D0 Stepping Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 -SLBEJ-$359.95
NCIX.com - Buy Intel Core I7 920 D0 Stepping Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 -SLBEJ- - BX80601920 - D0 In Canada.
Noctua NH-U12P SE1366 LGA1366 i7 Heatpipe Cooler W/ 2XNH-P12 120MM Fan [/color] -$79.99
NCIX.com - Buy Noctua NH-U12P SE1366 LGA1366 i7 Heatpipe Cooler W/ 2XNH-P12 120MM Fan - NH-U12P SE1366 In Canada.
EVGA X58 ATX LGA1366 DDR3 3PCIE-16 PCI-E1 2PCI SLI SATA2 eSATA Dual GBLAN Motherboard [/color] -$348.71
NCIX.com - Buy EVGA X58 ATX LGA1366 DDR3 3PCIE-16 PCI-E1 2PCI SLI SATA2 eSATA Dual GBLAN Motherboard - 132-BL-E758-A1 In Canada.
Mushkin XP3-12800 Ascent Redline 6GB 3X2GB DDR3-1600 CL6-7-6-18 240PIN DIMM Triple Channel RAM Kit-$240.52
NCIX.com - Buy Mushkin XP3-12800 Ascent Redline 6GB 3X2GB DDR3-1600 CL6-7-6-18 240PIN DIMM Triple Channel RAM Kit - 998692 In Canada.
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM-$105.98
NCIX.com - Buy Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM - WD1001FALS In Canada.
Corsair Professional HX850W 850W ATX 12V 70A 24PIN ATX Modular Power Supply Active PFC 140MM Fan-$229.99
NCIX.com - Buy Corsair Professional HX750W 750W ATX 12V 62A 24PIN ATX Modular Power Supply Active PFC 140MM Fan - CMPSU-750HX In Canada.
Samsung SyncMaster 245T 24IN Wide Black LCD Monitor 1920X1200 6MS VGA DVI Pivot HAS Spva Panel HDMI-$579.99
NCIX.com - Buy Samsung SyncMaster 245T 24IN Wide Black LCD Monitor 1920X1200 6MS VGA DVI Pivot HAS Spva Panel HDMI - LS24HUCEBQ/XAA In Canada
[/size]
[/size]
$1945.13 without pricematching. Move to a different monitor and you will have enough for a video card. Either an EVGA GTX 275 or ATI 4890 will do nicely. Note that these prices are all on the high side and that shopping around will save a bunch of $.
heatware
Old July 14, 2009, 10:03 PM
steers's Avatar
Originally Posted by stoanee View Post
<build omitted>
At the present moment, Core i7 builds do carry a bit of a price premium over architectures like the Core 2 or AMD's Phenom II, so this is around the price range you'll be looking at if you choose to go that route. For graphics work especially, if you value colour accuracy you're going to want to stick to a monitor with a *VA panel like what the Samsung 245T or Dell 2408WFP uses, or even better yet an IPS panel if you can find one. They're usually more expensive than monitors using TN panels (for 24", this usually means most monitors <$400), but you'll definitely see the improvement in the viewing angles and colour gamut (even if the input lag is usually higher than it is for TN panels).
A Phenom II build is comparably priced to the Core 2 Quad build above, and should offer about the same performance. I've sketched up a simple one on Newegg and attached it here.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
New build suggestions. taal CPU's and Motherboards 1 February 4, 2008 10:58 PM
Suggestions on WC build sswilson Water Cooling 18 September 19, 2007 03:05 PM
My build, suggestions? Magice CPU's and Motherboards 7 July 16, 2007 10:52 PM
first build, suggestions help? mgp141 CPU's and Motherboards 5 March 30, 2007 03:24 PM
Suggestions On New Build BALISTX CPU's and Motherboards 14 February 14, 2007 12:10 AM
