Old July 5, 2009, 04:05 PM
wonton1017's Avatar
Exclamation Opinion/Advice on this Budget Build
My budget for this PC is $750-$900CAD, i plan to buy my parts all from NCIX or directcanada. I dislike online computer stores like newegg and TD.
What i have in mind:
(Please let me know if i should change anything!)
IntelQ9550
ASUS P5Q Pro
Random OC'able 2x2gb dual channel ddr2-1066 ram
CM 690 case
WD 640GB Caviar black HDD
Not sure which PSU (Not planning to use 2x GPU at all)
Not sure which GPU (Might look for a used 8800GT for cheap for now or maybe a 4890 or GTX275 if i can find one for the right price.)
And which O/S should i use (dont count this in the budget) to game?
Should i upgrade/downgrade/change any of these parts?
Thanks, i'm planning to build this rig by the 12th.
Old July 5, 2009, 04:21 PM
3.0charlie's Avatar
You should do some shipping, 'cause with that parts list I don't think you'll meet your budget.
Hydro-Quebec is salivating...
Old July 5, 2009, 04:29 PM
sswilson's Avatar
I'm pretty sure you can do price match online with NCIX, but rather than ship, you can select to pick it up in the store. I've never done it so I'm not sure how it works.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old July 5, 2009, 04:33 PM
wonton1017's Avatar
Newegg.ca prices are higher than NCIX/Directcanada's arent they?
Which parts should i get online?
Old July 5, 2009, 04:36 PM
sswilson's Avatar
Ideally, do all of your initial shopping on-line to find the best prices for what you want, and then PM those prices on NCIX's website for local pickup.
Old July 5, 2009, 04:54 PM
wonton1017's Avatar
Does NCIX price match with Newegg?
Old July 5, 2009, 05:18 PM
Babrbarossa's Avatar
They'll PM newegg.ca although I have heard of cases where they refused.
Old July 5, 2009, 05:29 PM
wonton1017's Avatar
Alright thanks, i'll try PMing on Tuesday night after seeing their new deals.
Btw, are these parts fine? Should i change any of them? I'm not sure at all on the PSU and Case.
Old July 5, 2009, 05:47 PM
When you pm make sure you use more than one search engine pricebat, price canada and shopbot as some won't list other stores.
Old July 5, 2009, 06:04 PM
I would use a 64 bit OS
I would look for at gtx260 for 160-180
For PSU do you care if it's modular or not?
Opinion on i7/GTX 285 build Tikal New Builds 10 February 3, 2009 12:33 PM
Newbie Budget Gaming Advice Myzrah New Builds 40 July 23, 2008 05:49 PM
need advice on budget build thenewguy001 CPU's and Motherboards 11 May 19, 2008 02:08 PM
New Build- need advice, opinion Etc UberMoo Off Topic 1 December 17, 2007 10:20 AM
Need some advice for a low budget PC ebdoradz CPU's and Motherboards 14 December 14, 2007 08:52 PM
