<~----> E8400 Build - How is this purchase? Anything I need to change? - Hardware Canucks
Old July 2, 2009, 02:23 PM
Default E8400 Build - How is this purchase? Anything I need to change?
I know dual cores are getting outdated, but honestly, they are good enough for me.
I already have a 500GB HDD external, a 120GB internal HDD, and a 8600GT, and 5.1 PC speakers
Processor - Intel E8400 Core 2 Duo
Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail - DirectCanada
Motherboard - Gigabyte EP45-UD3L
Gigabyte EP45-UD3L ATX LGA775 P45 DDR2 PCI-E 2PCI SATA2 HD Sound GBLAN Motherboard - DirectCanada
Memory - G.SKILL F2-8500CL5D-4GBPK (2x2GB)
G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel Memory Kit - DirectCanada
Powersupply - Antec EA430 _is 430W enough?_
Antec Earthwatts 430W Power Supply ATX12V V2.0 20/24PIN Active PFC 80PLUS 80MM Fan - DirectCanada
Case - Coolermaster CAC-T05
Coolermaster CAC-T05 Centurion 5 Aluminum ATX Tower Case 5X5.25 1X3.5 4X3.5INT Blue Black No PS - DirectCanada
Newegg.ca - COOLER MASTER Centurion 5 CAC-T05-UB Black &#47;Blue Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Computer Cases
Sound Card (needed the optical IN so Xbox 360 can use 5.1 speakers)
HT Omega Striker 7.1 Channel PCI Sound Card 24BIT DTS Dolby Digital Live S/PDIF IN/OUT Coaxial - DirectCanada
Optical Cable (Need it to connect Xbox 360 to PC)
Ion Cable Optical Digital Audio Cable 6FT W/ Nylon Sleeve - DirectCanada
Wrist Strap
COMPUTER REPAIR ANTI-STATIC WRIST STRAP - DirectCanada
The grand total will be $634.86 Canadian dollars with free shipping, and $685.74 Canadian dollars with Purolator Ground.
Thanks a lot.
Old July 2, 2009, 02:40 PM
Jon_di2's Avatar
E8400's aren't outdated, you'll be good with it!
and 430 w is enough, but you should be able to find a good 500w psu for less then the price of that, there have been some good ones in ncix sales lately. (although that is a good brand if you decide to stick with it).
Not so sure about the sound card though... I think someone around here would be able to advise of a better one.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old July 2, 2009, 02:50 PM
Alright cool. I chose the HT Omega Striker because it got decent reviews and it seems solid.
The reason I need the sound card is because of the optical IN slot it has. i need to connect an optical cable to my Xbox 360, and the other side to the optical IN slot. That is the only way I can have 5.1 surround sound with the console and the PC at the same time.
Old July 2, 2009, 02:55 PM
Jon_di2's Avatar
Oh and your paying too much for the wrist strap:
DealExtreme: $1.75 Static-Release Wrist Strap
here 1.75 US, shipping included (there are more on the website if you dont like that style)
Old July 2, 2009, 02:58 PM
Cool, I'll check that out. Also, I think the sound card comes with an optical cable, so I'll have to research on that some more.
Old July 2, 2009, 03:07 PM
stoanee's Avatar
E8400 are NOT outdated. I had one that ran 4 ghz stable and ran very well. Highly recommended.
heatware
Old July 2, 2009, 03:09 PM
According to newegg, the sound card does come with an optical cable.
Newegg.ca - HT &#124; OMEGA STRIKER 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Sound Cards
It would have been nice if DirectCanada mentioned this on their site; would have saved me some trouble :P
Old July 2, 2009, 03:11 PM
Yeah, hopefully I can manage to OC that high!
Old July 2, 2009, 03:33 PM
Aww, I just got an email response from directcanada and for some reason, their HT Omega Strikers do not have the optical cable . . .
Old July 2, 2009, 05:22 PM
Realityshift's Avatar
Wrist straps are over rated, just ground yourself once in a while and youll be fine.
The Builders Hammer
About to purchase tim333 New Builds 9 April 9, 2009 09:58 AM
Antec 900 | E8400 build ver 2.0 Mr. Gruntsworthy New Builds 24 October 3, 2008 03:44 PM
Antec 900 | E8400 build Mr. Gruntsworthy New Builds 43 September 26, 2008 04:55 PM
Final Build Before Purchase - Please advise! LegendofJubei New Builds 4 August 20, 2008 05:18 AM
Which ram should I purchase??? mattydies RAM 5 August 7, 2007 10:00 PM
