  #21 (permalink)
Old July 3, 2009, 08:08 PM
Alright cool. Hopefully I'll be able to install the fan. . .
  #22 (permalink)
Old July 4, 2009, 07:05 PM
Guys, I have a question. According to this video:
YouTube - Tiger How To: Install a Motherboard
I HAVE to use a orange screwdriver. Why is that? I just have a regular star head screwdriver. . . would that work?
  #23 (permalink)
Old July 4, 2009, 07:35 PM
Realityshift's Avatar
Yes you dont need to use any sort of special screw driver to install a motherboard, the screws are all standard.
The Builders Hammer
  #24 (permalink)
Old July 4, 2009, 08:23 PM
rjbarker's Avatar
Prefit you Mobo first and ensure all screws lign up to stand-offs accordingly...then..:
1. Remove from Case and install CPU / HSF
2. Install RAM
3, Install GPU and plug in HDD
4. Plug in PSU cables and Case Power / Reset/ HD LEd etc
Boot up and ensure all is operating correctly
Then install into your Case....cable management etc
5. Install OS / Drivers
Done
Now benchmarks !!!
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
  #25 (permalink)
Old July 5, 2009, 12:07 AM
I usually just install it into my case before testing, without a decent open test bed I dont really like having the motherboard just laying on anything ;)
The Builders Hammer
  #26 (permalink)
Old July 5, 2009, 09:42 AM
rjbarker's Avatar
The box it came in is just fine.
  #27 (permalink)
Old July 10, 2009, 10:51 PM
Holy hell, installing the push pins is impossible. . . any advice?
I'm ready to commit suicide.
  #28 (permalink)
Old July 11, 2009, 07:13 AM
Nevermind, I finally got it on.
Quick question though, what does the arrow mean on the front panel connectors? Does it signify pin 1?
  #29 (permalink)
Old July 11, 2009, 03:43 PM
DrPepper's Avatar
in benchmarks, the e8400 is faster than the entry-level quads(6600, 8200) and save yourself on the wristwrap, build the system on a room with wood flooring, and no carpet
About to purchase tim333 New Builds 9 April 9, 2009 09:58 AM
Antec 900 | E8400 build ver 2.0 Mr. Gruntsworthy New Builds 24 October 3, 2008 03:44 PM
Antec 900 | E8400 build Mr. Gruntsworthy New Builds 43 September 26, 2008 04:55 PM
Final Build Before Purchase - Please advise! LegendofJubei New Builds 4 August 20, 2008 05:18 AM
Which ram should I purchase??? mattydies RAM 5 August 7, 2007 10:00 PM
