Old July 2, 2009, 06:18 PM
Originally Posted by Realityshift View Post
Wrist straps are over rated, just ground yourself once in a while and youll be fine.
This is going to be the first computer which I will build myself, and I do not want to fry something :P
Old July 2, 2009, 06:23 PM
Realityshift's Avatar
Yeah but parts these days are far less suseptible to static shock, ive put together over a dozen systems without even worrying about grounding myself without any issues ;) just tryin to save you some money.
The Builders Hammer
Old July 2, 2009, 07:08 PM
Oh yeah, is the stock heatsink good for overclocking or should I buy a better one?
Old July 2, 2009, 07:09 PM
rjbarker's Avatar
There are quite a few HSF assemblies out thier that will cool that OC'd E8400 nicely....definitely get some sort of aftermarket cooling solution!!!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old July 2, 2009, 07:43 PM
When you say aftermarket cooling solution . . . do you mean like an aftermarket CPU fan/heatsink?
Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM - DirectCanada
Old July 2, 2009, 07:44 PM
Cowboy's Avatar
Looks good to me should be fine for a non-gaming build
Old July 2, 2009, 08:11 PM
And should I get this thermal paste or is it unnecessary?
Arctic Cooling MX-2 Thermal Compound Paste NON-ELECTRICAL Conductive 4 Gram - DirectCanada
Old July 2, 2009, 08:26 PM
rjbarker's Avatar
Yep.....
That paste will work fine....the E8400 chips don't run as warm as thier Quad Core counterparts....
MARK 11: 32.530
  #19 (permalink)
Old July 2, 2009, 09:40 PM
Alright cool, and I added this cooler. . .
Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - DirectCanada
  #20 (permalink)
Old July 3, 2009, 01:02 PM
Im running that cooler on an E8400 right now and it cools like a champ, 3.6ghz and even with my room temps being around 24c my CPU loads at under 55c =) great cooler for the price. Mines an older C0 stepping CPU to, chances are youll get an E0 which will overclock with less voltages and therefore less heat.
The Builders Hammer
About to purchase tim333 New Builds 9 April 9, 2009 09:58 AM
Antec 900 | E8400 build ver 2.0 Mr. Gruntsworthy New Builds 24 October 3, 2008 03:44 PM
Antec 900 | E8400 build Mr. Gruntsworthy New Builds 43 September 26, 2008 04:55 PM
Final Build Before Purchase - Please advise! LegendofJubei New Builds 4 August 20, 2008 05:18 AM
Which ram should I purchase??? mattydies RAM 5 August 7, 2007 10:00 PM
