Old June 28, 2009, 08:18 AM
Gensol's Avatar
Question Need help upgrading on a budget.
Hi Gents,
I could use your opinions and help. I need to replace my motherboard and cpu. I broke a capacitor off my motherboard and haven't noticed any problems yet but I figure it is the push I need to upgrade anyways.
Since my budget is only about $300-$400 I will only be replacing my motherboard and cpu currently.
Right now I run;
Antec Sonata I
Antec Earthwatt 500w PS
P5B-VM motherboard
Core 2 Duo 2.13 (old 6420)
4 gigs of 667 Kingston DDR2 Value Ram
(I run windows xp home 32bit so it only sees 3.4 or some such)
Sapphire HD 2600XT GPU
Seagate 160G SATA HD
I would like to replace the motherboard and CPU with something AMD. I have never had an AMD before and I would like to try them since they tend to be cheaper than Intel but I am still open to Intel if it is the best way to go for now. I can also scrape some money to replace my RAM if you guys see fit.
My computer is used mostly for light gaming and web surfing. COD4 is my most graphically intensive game right now. I will eventually upgrade my GPU as well but I wanted to start with the motherboard and cpu. I am not a big overclocker. Actually I wouldn't even know where to start. I will browse the latest in HDs. The reason I picked AMD is that the prices on AMD tend to be a lot lower than Intel. The new Phenom cpus have had a lot of amazing press lately so I figured I would try it out.
A couple of additional questions. Will my power supply last me a while? I just had it installed after buying it at Christmas when NCIX put it on sale. Are the Phenom IIs that much better than the Athlons out there? Value to performance wise?
Thanks for all the help guys.
Kris. :help:
"A woman drove me to drink ... and I hadn't even the courtesy to thank her." - W C Fields
Old June 28, 2009, 10:51 AM
The x3 720BE is a good start at $139 + free shipping at newegg.ca then pick out a mobo there or any other etailer that has a good deal.The 720BE is overclock friendly it has an unlocked multi.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old June 28, 2009, 11:22 AM
rapmaster's Avatar
this is the best performance for the buck motherboard and CPU
Buy Gigabyte [GA-MA770-UD3] Gigabyte GA-MA770-UD3 ATX AM2+/AM3 AMD770 PCI-E16 2PCI SATA2 RAID 1394 HD Sound GBLAN Motherboard
Infonec Computers - Computer parts Canada, PC Components, laptop computers, motherboards, processors, CPUs and much more : AMD Black Edition - Processor - 1 x AMD Phenom II X2 550 / 3.1 GHz - Socket AM3 - L3 6 MB - Box
Quando omni flunkus moritati
Old June 28, 2009, 11:50 AM
Canada Computers - Motherboards > Socket AM2+ : Gigabyte GA-MA770-UD3 Socket AM2 AMD 770 + SB700 Chipset Dual-Channel DDR2 1200/066Mhz 6x SATA 3Gb/s 7.1- Ch HD Audio Gigabit Lan IEEE1394 PCI-Express 2.0 Graphic Slots ATX. Here's the same mobo with $6.99 shipping. For the price difference I'd stay away from x2 cpu even though the 550 can possibly unlock the other 2 cores but it's not a sure thing. These guys got it too Xpress Canada - Motherboards > Socket AM2+ : Gigabyte GA-MA770-UD3 Socket AM2 AMD 770 + SB700 Chipset Dual-Channel DDR2 1200/066Mhz 6x SATA 3Gb/s 7.1- Ch HD Audio Gigabit Lan IEEE1394 PCI-Express 2.0 Graphic Slots ATX.
Ps; yes the phenomII even at stock 3ghz (overclocked 3.5ghz at 1.4v and ht 2000mhz all the time)is far better than my x2 6000 clocked to 3.4ghz.
x3 720 $140 free shipping
Ga-ma 770 $80+$6 shipped
$226 + whatever tax.
A WD 640GB 32MB Black would be a nice upgrade to u'r hdd they go for about $78.
Old June 28, 2009, 11:57 AM
Your power supply should last you just fine, unless there's something you're not telling us about it . An Antec EarthWatts can actually deliver 500W for some time, and your computer doesn't even get close to that mark.
I estimate your rig's power consumption at:
95W (non-OC'd CPU) + 25W (mobo) + 15W (hard drives) + 50W (Radeon HD2600) = 185W << 500W
The older Athlon X2s can barely beat your current E6420, especially if you overclock. I'd actually stick with your older CPU (if it still works) rather than invest in an equally outdated Athlon X2. If you're going for more cores, get a Phenom II because the older Phenoms have horrible heat and idle power consumption. So +1 to the suggestion of Phenom II 720.
Old June 28, 2009, 12:37 PM
Gensol I had an after thought , is that sonata1 an atx or matx case?
Old June 28, 2009, 02:18 PM
Gensol's Avatar
The Sonata is an ATX case. I just use a mATX because at the time of purchase I needed onboard video.
If I decide to keep the CPU, which motherboard should I look for then? You make a good point about keep a perfectly good CPU. It still runs fine. It would likely wind up in a landfill somewhere. :(
Old June 28, 2009, 02:43 PM
rapmaster's Avatar
get a nice P45 board
Gigabyte EP45-UD3R ATX LGA775 P45 DDR2 1366+ 1PCI-E SATA2 RAID HD Sound GLAN 1394A Motherboard - DirectCanada
If you want something cheaper
Gigabyte EP45-UD3L ATX LGA775 P45 DDR2 PCI-E 2PCI SATA2 HD Sound GBLAN Motherboard - DirectCanada
Old June 28, 2009, 03:04 PM
bissa's Avatar
CPU
NCIX.com - Buy Intel Pentium Dual Core E5200 Dual Core Processor LGA775 2.5GHZ 800FSB 2MB Retail Box - BX80571E5200 In Canada. $80
I am running this stable at 3.6 on the same motherboard using air cooling
MB
Gigabyte EP45-UD3R ATX LGA775 P45 DDR2 1366+ 1PCI-E SATA2 RAID HD Sound GLAN 1394A Motherboard - DirectCanada $115
which leaves some extra for other stuff you find on the way.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old June 28, 2009, 03:08 PM
rapmaster's Avatar
I don't recommend to get the e5200, it's not a upgrade. Keep your CPU and get yourself a good p45 and overclock your CPU.
need help upgrading muffler New Builds 11 March 28, 2009 05:59 AM
Looking at upgrading for Folding crazyhorsejohnny HardwareCanucks F@H Team 27 January 28, 2009 02:38 PM
Upgrading (at last) Mysteryous Video Cards 0 January 5, 2009 09:32 PM
Upgrading again....FS !!! crazyhorsejohnny Buy/Sell & Trade 35 November 5, 2008 03:31 PM
So Im thinking about upgrading tgraszat14 Video Cards 4 May 13, 2008 04:31 PM
