  #21 (permalink)
Old June 25, 2009, 07:29 PM
Soultribunal's Avatar
Originally Posted by rjbarker View Post
The Antec 900 is old in the tooth and imo, not worthy of any I7 build...particularly if your even thinking about SLI in the future, get a Case with more "breathing room"....as for GPU's, the GTX 275's seem like a great deal right now...pick up 2 of em and "hold on" for the ride...
Agreed RJ.
You know though, the Scout is amazing to work in. I'd recommend that in a heart Beat.
ST
www.realhardwarereviews.com
  #22 (permalink)
Old June 26, 2009, 03:04 PM
I really like the mobo/proc deal. However, the mobo is not the p6t deluxe, just the p6t. What's the tangible difference?
Final Build:
gtx 275 SLI
i7 920
Western digital 1TB HDD
mobo: P6t or P6T deluxe?
Corsair 3x 2 GB
Corsair 850W PSU
I could see myself doing some OC (only if I can't play games on their best setting) but not to high or ridiculous levels. Does the P6T (non-deluxe) have raid? I couldn't find that mentioned anywhere. When I start working (software eng), I would like to set up RAID 1 for redundancy. Can't risk a drive dying and losing valuable work.
  #23 (permalink)
Old June 29, 2009, 12:32 PM
Wurmer's Avatar
Case wise, I'll add my 2 cents. Go with the HAF 932. Yes it's big but it's one hell of a case. Firstly, it's cavernous and will provide you with ample room for current and future built. Ventilation is awesome and cable management is a charm. The downside is that it's not cheap but it's worth every penny.
$1500 i7 Build, need some help :P Bumchoda New Builds 18 May 27, 2009 06:49 PM
Build for a CDN Soldier. BALISTX New Builds 142 October 27, 2008 05:43 PM
$1500 first build GhostOps New Builds 34 October 27, 2008 04:12 AM
$1500 case build, advice/suggestions needed moxmonkey New Builds 23 September 3, 2008 01:13 PM
New Build ($1500) miggs78 New Builds 8 August 6, 2008 12:09 AM
