Old June 25, 2009, 11:00 AM
martin_metal_88's Avatar
NCIX.com - Buy XFX Radeon HD 4890 XT 1GB 875MHZ 1GB 3.9GHZ GDDR5 PCI-E 2XDVI HDTV Video Card - HD489AZDEC In Canada.
This one is good awith realy good price. XFX are pretty new with ATI but they take with them some experience from Nvidia. Great card at great price.
Old June 25, 2009, 01:13 PM
Thanks again, I think I'lll go with the XFX.
Anyways, you guys got me thinking. Could someone give me an overview of the major Canadian hardware sites? Like which ones of free shipping on major purchases, which ones should be avoided, etc... I.E. I heard newegg offers good deals but you have to pay through the teeth for shipping.
These are the sites I've been considering:
tigerdirect.ca
newegg.ca
ncix.com
directcanada.ca
Old June 25, 2009, 01:52 PM
Where are you located? Just cause directcanada and ncix are both located in BC and if you don't live in BC you don't pay PST. So that's 8% there.
I think NCIX is most popular around here, just cause you can price match and their customer service is pretty decent and they generally respond pretty quickly. If you wait for one of their gift card = free shipping you can save on shipping too. They just had one last week 10$ gift card = free shipping for entire order.
Old June 25, 2009, 02:26 PM
Mr. Gruntsworthy's Avatar
While the Antec 900 is a nice case (it's the one I use), I've recently become rather attatched to CoolerMaster cases. In particular, the CM 690. Somebody earlier suggested the HAF 932, but that's a full tower case, and way too big for what you're using. Even with crossfired cards, you'll be able to fit that into the CM 690 quite nicely. It's even a relatively cheap case, but you'll need to purchase additional fans to completely deck out your case. the 690 is a beast, definitely the case i'm using for my next build. :)
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
Old June 25, 2009, 02:52 PM
rjbarker's Avatar
The Antec 900 is old in the tooth and imo, not worthy of any I7 build...particularly if your even thinking about SLI in the future, get a Case with more "breathing room"....as for GPU's, the GTX 275's seem like a great deal right now...pick up 2 of em and "hold on" for the ride...
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 25, 2009, 03:48 PM
Ncix is just amazing at the moment, really cheap shipping deals (gift card = whole order free shipping) compared to newegg, price-matching, and some really good deals atm (customer appreciation sale). The best thing about them is that they only charge GST if your outside of BC, compared to newegg and tiger direct which charges you the full tax, which makes a huge difference when making big orders. Tigerdirect would be my second choice because they have probably the best deals and really cheap shipping, just dont use them if your order is going to be huge.
Old June 25, 2009, 03:56 PM
I'm in Ontario. Wow. The graphics card is giving me a headache.
Two more questions:
1. Best bang for the buck: gtx 260 in dual SLI or 4890 in dual Xfire? If it's negligable, I'd prefer to go with the nVidia (slightly cheaper, too). I've heard the SLI drivers are more stable than Xfire. Am I wrong this?
2.I know the 932 is very big, but would going with it be a disadvantage in any ways aside from being ridiculously spacious? I like the way it looks, and it seems to have excellent airflow and room for upgrades.
P.S. I know I was the one who brought the 275s up, but I looked deeper into and they're too expensive at the moment. Or should I go with a single 275 and upgrade to SLi when they get cheaper?
Old June 25, 2009, 04:18 PM
CroSsFiRe2009's Avatar
GTX 260 SLI vs 4890 in Xfire is a bit of an unfair comparison. GTX 275's in sli vs the 2 4890s would be more appropriate. If you absolutely can't spend more, go with the cheapest option which would be the 260's in this case. If you can, I'd go for the 275's since you can also do some folding in your spare time.
nothing wrong with liking the 932, IMO, get a CM 960 instead and use the cash for the 275's
MSI GeForce GTX 275 Twin Frozr OC 666MHZ 896MB 2.322GHZ GDDR3 PCI-E 2XDVI Video Card
Pretty good deal for that 275 considering it's a nice non-stock cooling version too and even better if you can get somebody to help you get the 2nd rebate if you go sli
As for upgrading to sli later on, I don't think it's a good idea since most likely, a better card will be out by then.
  #19 (permalink)
Old June 25, 2009, 04:32 PM
Thats a really good deal if you consider a 275 can outbenchmark a 280. I personally, would not get SLI simply because you wont be able to use its full potential in most cases.
  #20 (permalink)
Old June 25, 2009, 07:16 PM
For a cheap and good CPU cooler, I will sell you my CM V8 for a mere $50.
$1500 i7 Build, need some help :P Bumchoda New Builds 18 May 27, 2009 06:49 PM
Build for a CDN Soldier. BALISTX New Builds 142 October 27, 2008 05:43 PM
$1500 first build GhostOps New Builds 34 October 27, 2008 04:12 AM
$1500 case build, advice/suggestions needed moxmonkey New Builds 23 September 3, 2008 01:13 PM
New Build ($1500) miggs78 New Builds 8 August 6, 2008 12:09 AM
