<~----> Finished rig questions - Hardware Canucks
Old June 24, 2009, 10:45 AM
Default Finished rig questions
Hello,
I just finished my first build, I have a few questions about it, but I will start by the begining.
While running Prime95, Core temp says my CPU goes up to 59C, Easy Tune says its at 53C. I've got my 2 TriCool running at medium. The room temperature is fairly warm, I wouldn't be surprised if it was more than 25C. The GPU in comparison is at 63C(based on easy Tune).
Are my temps normal ?
Here is my system:
Antec P183
CP-850
Phenom II X4 940
OCZ Vendetta II
Gigabyte MA790x-UD4P
G Skill 2x2gb PC2-6400
WD10EADS
LG GH22NS30
XFX 4890
2x Noctua NF-S12-1200 fans
I plan to overclock a bit, but I would like some advice, suggestions and just opinions on my temps and system.
Thanks a lot.
Edit: btw, its my 1st rig I build.
Old June 24, 2009, 10:59 AM
jcmaz's Avatar
I would use Rivatuner for your XFX 4890, Core Temp & Everest & CPUID Hardware for your CPU. I'm not sure if they are normal, but when my cpu is stressed, it goes up to ~65 degrees w/ the crappy stock dust clogged cooler.
-Plato
Old June 24, 2009, 11:04 AM
Supergrover's Avatar
I find HWmonitor and everest are two programs that acttally give me the correct temps for my Mobo.
Coretemp doesnt work with my unlocked 720 and the mobo's monitoring software reads the temps 11c under what they are.
@ load I'll hit 55c with 1.4v under water
R.I.P.
Old June 24, 2009, 12:54 PM
hossdaddy's Avatar
compare those reported temps vs what the bios tells you. I realise you cannot do this while stress testing but if its reporting accurately at start up I would assume that its accurate for the rest.
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old July 1, 2009, 02:30 PM
Sorry to bring this back up but my interogations have not been answer yet and my questions remain.
I am not too worried about the GPU because I don't see what I could have done wrong. It runs about 6 degrees hotter than the XFX 4890 XT tested on an open bench at HWC, but my room is surely warmer and I am in a case.
However, the CPU, idling at 39-40 degrees seems a bit warm considering I am using an OCZ Vendetta CPU cooler(I have upped the multiplier to x17). Under 100% load, it gets to 57 degrees with my tri-cool at medium. I used the thermal paste that came with the cooler even if I know its not the best... I am wondering if its normal or if there is a problem user related.
And no, I am not having any problems what so ever with my computer, would just like to make sure I have done everything properly. Applying thermal paste is by far the thing I felt the most uncomfortable with.
Old July 1, 2009, 05:40 PM
Realityshift's Avatar
Thats probubly about normal id say, the GPU just needs a bit of a fan speed tweak to lower the temps, that CPU should be good at where its at especially if its in a warm room. Its a tad warm but my E8400 idles at 40c per core and hits 55c when stressed, It could be that your CPU heatsink isnt set right or you didnt apply thermal paste correctly, but I wouldnt be alarmed by the temps, it is a quadcore afterall.
The Builders Hammer
Old July 1, 2009, 08:11 PM
Any idea on how I would know if I did not applied the thermal paste properly ?
Also, what is your GPU temperature, so I can compare on something that actually has information about.
Or, I am also looking for information about the X4 940's temperature.
Old July 2, 2009, 12:26 AM
Well my GTX 260 idles at 40c and loads at between 60 and 70c depending on room temps, I cant help you with the CPU temps youll have to just search some reviews or wait for someone who has one to apear. Youll know the paste or HSF isnt installed propperly when you have unusually high temps.
The Builders Hammer
Old July 2, 2009, 09:05 AM
Cowboy's Avatar
Those temps are kinda high for a 940BE. I had one on air for a little while and it never got that hot with stock Vcore and stock multi.
For the deneb core, it is recommended to keep temps under 60C, so as long as it maxes out at 55C at load you should be fine.
How did you apply the thermal paste? How many fans have you got on your noctua? is it seated correctly?
Something's up, I'll tell you that. And I'm going to try to help you figure out what it is.
Old July 3, 2009, 09:04 PM
Sorry if it took a lot of time for me to reply. Thanks a lot for the offer Cowboy, I appreciate it.
Today I reseated the heatsink in the case. I used Isopropyl to clean the thermal paste and I reapplied it, made sure to fill the gaps and I applied a thin layer and I spread it with a card.
After that the temperatures were: 37 at idle and 49-50 when running Prime 95.
I also lowered to stock speed and the temperature was 29-30.
The room temperature was also a bit lower today I think.
The set up in the case is 2 Noctua NF-S12-1200 set as intake fans, 2 Antec tri-cool as exhaust, they are set to run on medium. The OCZ Vendetta II's pushes the air towards the top of the case, its placed almost directly under the top tri-cool.
One thing I have been considering is to either add or move my lowest Noctua to the top of the case, but for that I would have to do the "assembly" myself.
What are your temps Cowboy ? What is your setup ?
1st build gaming rig questions aviduser New Builds 5 February 9, 2009 11:33 AM
Basic questions for a 4870 rig Bucklaz New Builds 13 December 27, 2008 12:02 AM
Questions on my new rig. xile042 New Builds 5 December 11, 2008 09:20 AM
New rig finally finished ... for now NyteOwl Case Mods, Worklog & Gallery 8 September 3, 2008 08:37 PM
never finished flybye Case Mods, Worklog & Gallery 1 September 11, 2007 10:42 AM
