Old July 4, 2009, 01:44 PM
As it is now, I put the computer at stock speed and today my room is fairly cool (probably 20ish) and the CPU is not running at all, I opened the case to check and the CPU is at 27 degrees, not idle, but pretty close to it.
Old July 4, 2009, 02:57 PM
Realityshift's Avatar
I dont think you ever told us what you had that processor overclocked to originally, I thought we where working with stock clocks when you said your temps where high, those stock temps dont seem high at all even though they are only idle temps. What was your CPU overclocked to when you reported the temps to us?
The Builders Hammer
Old July 4, 2009, 04:25 PM
Sorry, its my bad, I was sure I said it unless I had not tried that at the time of the original post... Anyway, it was a mild oc cuz I wasn't comfortable with the temps (and its my 1st time ocing). I just raised the multiplier to x17, so it was oc'ed at 3.4ghz.
Edit: After reading the dates and times all over again, the 1st post was not oc'ed, it had just been a few hours the rig was up and running, I later started to oc, I mentionned it when I did, but I should have restated it in my other posts.
1st build gaming rig questions aviduser New Builds 5 February 9, 2009 12:33 PM
Basic questions for a 4870 rig Bucklaz New Builds 13 December 27, 2008 01:02 AM
Questions on my new rig. xile042 New Builds 5 December 11, 2008 10:20 AM
New rig finally finished ... for now NyteOwl Case Mods, Worklog & Gallery 8 September 3, 2008 08:37 PM
never finished flybye Case Mods, Worklog & Gallery 1 September 11, 2007 10:42 AM
