Old June 10, 2009, 08:52 PM
Beermaster's Avatar
Default Need help with new build
Hey guys, bad new is my current set up just died on me /cry
Good news is Wife said, go ahead build a new one!!! WEWT
So think of going i7, and of course reading all the reviews on the boards latey have me drooling, but do i need all that high end stuff? i dont think so!
I am not going to go multiable video cards, so getting a triple SLI is kinda a waste for me i think? I do game, but i play WoW so really dont need all that high end video of triple sli.
So what i am asking is, what motherboard would you recommend? I do video and picture editing, WoW, watch movies, stream movies to my PS3 ect....
not really into overclocking, but am going to liquidcool it, becasue i want to lol
thank for the advice, and of course like last time i buiilt one, i will do a review of the build and hardware )i know that was 2 years ago, but hey lol)
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov – Acer One*8gb SSD*WinXP pro
Tathar – WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old June 10, 2009, 08:56 PM
You should list it like it is in this topic -- NOTICE - PC builders, when asking for input on YOUR projects Please Tell
By the sounds of it you're looking for a midrange gaming rig.
Old June 10, 2009, 09:03 PM
Beermaster's Avatar
1. What YOUR PC will be used for. That means what types of tasks you'll be performing. video and picture editing, WoW, watch movies, stream movies to my PS3 ect
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread -- $2500
3. What country YOU will be buying YOUR parts from. Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture. i prefer to go intel over amd
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. New build top to bottom
6. IF YOU have searched and/or read similar threads. Yes, and no,
7. IF YOU plan on overclocking or run the system at default speeds. Default
8. WHEN do you plan to build it? This weekend if i can get the parts
Old June 10, 2009, 09:04 PM
Beermaster's Avatar
Thanks for the heads up, Filled it all out, but really didnt give much more info then what i had in the first post
Old June 11, 2009, 12:13 AM
Realityshift's Avatar
Hmm thats a huge budget for what you need, personally id just grab a good AMD 790X motherboard, a ATI 4770,4850, or an nivida GTS 250 (both come in around the $120-$140 mark normally), either an x3 720 BE tri core processor or an x4 940 BE quad core.
Ram wise go with G.Skill and grab some DDR2 8000s, they will normally run you around $55 and are great ram moduals. Throw in a decent case, coolermaster have some very nice ones, also the antec 902 is decent, but if your willing to spend more take a look at the silverstone fortress case or some of their others, a little pricy but awesome cases. Try and grab a decent 550w psu like a corsair VX550 or maybe the modular 520. For hard drives stick with the western digital black dual processor ones, their roughly the same price as other but quite a bit faster, the 640gb ones are great because of the dual platters they are quite zippy. For DVD writers stick with samsung or panasonic, LG isnt bad but ive had some problems with them in the past.
That build wont cost more then $1200 or so and more then likely that includes a monitor. use the RC version of windows 7 for free untill june 2010 and save yourself some cash. If your want a little horse power for desktop computing the quad will help a little (video conversion) if not the x3 720 is pretty good for a gaming PC. If your not overclocking though you could change that up to an intel P45 motherboard and an E8400, that set up is going to be faster without overclocking when gaming then either of the phenoms.
Tri core
NCIX.com - Buy AMD Phenom II X3 720 Black Edition Triple Core Processor AM3 2.8GHZ 7.5MB Cache 95W 45NM Retail Box - HDZ720WFGIBOX In Canada. $174
Motherboard
NCIX.com - Buy Gigabyte MA790X-UD4P ATX AM3 AMD790X DDR2 CrossFireX 2PCI-E 2PCI SATA2 Sound GBLAN Motherboard - GA-MA790X-UD4P In Canada. $134
4770
NCIX.com - Buy Radeon HD 4770 750MHZ 512MB GDDR5 3.2GHZ PCI-E Dual DVI-I - AMD-ATI-RADEON-4770-512MB In Canada. $139
Power Supplies
NCIX.com - Buy OCZ FATAL1TY 550W ATX12V 20/24PIN Active PFC ATX Modular Power Supply 120MM Fan 80PLUS Black - OCZ550FTY In Canada. $69 AMIR or
NCIX.com - Buy Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM Fan - CMPSU-550VX In Canada.
$119 (corsair is a bit better quality and has more power on the 12v rail)
Cases
NCIX.com - Buy Silverstone Fortress FT01-BW ATX Black Aluminum Case 5X5.25 7X3.5INT No PS W/ Window - SST-FT01-BW In Canada. $256
NCIX.com - Buy Coolermaster Haf 922 Mid Tower ATX Case Black 5X5.25 5X3.5INT Front Audio USB eSATA No PSU - RC-922M-KKN1-GP In Canada. $156
NCIX.com - Buy Cooler Master Haf 932 Full Tower Black EATX Case 6X5.25 1X3.5 5X3.5INT No PSU USB eSATA 1394 Audio - RC-932-KKN1 In Canada. $177
NCIX.com - Buy Coolermaster Storm Sniper Mid Tower ATX Case Black 5X5.25 5X3.5INT No PS Front USB Sound & eSATA - SGC-6000-KKN1 In Canada. $196
NCIX.com - Buy Antec Nine Hundred Two Mid Tower Gamer Case 902 ATX 9 Drive Bay No PS Top USB2.0 eSATA Audio - NINE HUNDRED TWO In Canada. $159
Hard drives
NCIX.com - Buy Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - WD6401AALS In Canada. $77
NCIX.com - Buy Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM - WD1001FALS In Canada.
$108 (if you want 1tb drives id go with the greens though they are a bit quieter.)
NCIX.com - Buy Western Digital WD10EADS Caviar Green 1TB SATA 32MB Cache 3.5IN Hard Drive OEM - WD10EADS In Canada. $85
DVD burner
NCIX.com - Buy Samsung SH-S223F Black 22X DVD Writer SATA OEM - SH-S223F/BEBE In Canada. $31
Ram
NCIX.com - Buy G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB 2X2GB DDR2-1000 CL5-5-5-15 240PIN Dual Channel Memory Kit - F2-8000CL5D-4GBPQ In Canada. $59
Quad core
NCIX.com - Buy AMD Phenom II X4 940 Black Edition Quad Core Processor AM2+ 3.0GHZ 8MB Cache 125W 45NM Retail Box - HDZ940XCGIBOX In Canada. $250
Intel platform
NCIX.com - Buy Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail - BX80570E8400 In Canada. $189
NCIX.com - Buy Gigabyte EP45-UD3R ATX LGA775 P45 DDR2 1366+ 1PCI-E SATA2 RAID HD Sound GLAN 1394A Motherboard - GA-EP45-UD3R In Canada. $133
Other video card options
NCIX.com - Buy Gigabyte Radeon HD 4850 625MHZ 512MB 1.92GHZ DDR3 PCI-E CrossFireX DU-DVI-I HDCP HDTV Out Video Card - GV-R485ZL-512H In Canada. $128 AMIR
NCIX.com - Buy EVGA E-GEFORCE GTS 250 756MHZ 512MB 2.2GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card - 512-P3-1150-TR In Canada. $134 AMIR
GTX 260 =D might be overkill but maybe youll want to play more then wow later on ;)
NCIX.com - Buy BFG GeForce GTX 260 OC MAXCORE55 590MHZ 896MB 1.998GHZ GDDR3 PCI-E Dual DVI-I HDTV Out Video Card - BFGEGTX260MC896OCDE In Canada. $164 AMIR
The Builders Hammer
Old June 11, 2009, 12:30 AM
NCIX.com - Buy Corsair TX850W 850W CMPSU-850TX 12V 70A 24PIN AT Power Supply Active PFC 140M Fan Powersupply - CMPSU-850TX In Canada.
Just noticed that, cheaper then the 550w ;)
NCIX.com - Buy NCIX Gaming Bundle Deal XFX Radeon HD 4890 XT 1GB PCIe Video Card & Corsair TX750W Power Supply - 4890-750W In Canada.
The Builders Hammer
Old June 11, 2009, 12:44 AM
For what you want i7 is a waste.
Either stick with 775/AM2 or wait for i5
Old June 11, 2009, 06:39 AM
Beermaster's Avatar
Well cant wait for i5 unless it is out next week lol
So your suggesting to go 775 then, hmmm never really though about that, i guess i just ASSUMED that going i7 was the next logical choice (new stuff right).
I dont mind building to over meet what i need, cause you never know what game might catch my eye, and i want to be able to play it smoothly. One thing i forgot to add is that i run 2 24" Samsung LCD monitors, not sure if that makes a difference or not, but............
Old June 11, 2009, 07:25 AM
Prof. Dr. Silver's Avatar
WOW.... Spending someone elses $ 2500 is fun! Here's my suggestion:
Intel Q9550 $ 250 (Jump on this!)
Mobo: GA-EP45-UD3P $ 147 (after $ 20 MIR)
GPU: GeForce GTX 275 $ 268 (after $ 20 MIR) (Good for rendering video in CS4???)
Ram: OCZ Reaper 4Gb PC-8500 $ 77 (after $ 20 MIR) (x2 for 8 Gb if you render a lot of video...)
SSD for OS: OCZ Vertex 120Gb $ 446 (FAST!!) Edit... Just spotted this one for $ 369!!!
HDD for storage: WD 1Tb WD1001FALS Caviar Black $ 109 (HUGE!!)
PSU: Corsair TX850 $ 110 (after $ 34 MIR)
CPU Cooler: Xigmatek HDT-S1283 $ 39 (after $ 5 MIR)
This totals $ 1523 which leaves you $ 977 for a case, dvd/blue-ray and other fun peripherals you might need! Oh and install W7 64-bit for free until it becomes available for purchase!
This will be a kick-ass system! More then what you need and good for a while to come! You like???
Ps. Don't forget to pricematch! You might save a few dollars here and there!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old June 11, 2009, 07:47 AM
Beermaster's Avatar
Oh Wow
See i never thought of going with 775, figured because i can only upgrade every 3 years
Originally Posted by RealityShift
atleast that's what the ball and chain says...
, that going i7 was my only choice, but you guys have shown me a different window to look at..........
and being my first liquid cooled attempt, i am really really excited :D :D :D
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
