  #21 (permalink)
Old June 11, 2009, 02:46 PM
Realityshift's Avatar
Im thinking you mean CS4 as in adobe CS4? as in you dont have to render ... anything in CS4 on a cude video card, if perhaps it was a full 3d rendering in something like 3dsmax, c4d, or autocad, where openGL rendering really counts then ya the GTX 275 would be worth it. Or if you plan on playing alot of newer video games right away, otherwise its not going to make your CS4 experience all that much faster then the quad core already will.
If your looking at coolit, with a quad the freezone elite is probubly the only one you want to look at, the pure is pretty lacking in cooling power. You dont need watercooling unless you plan to do some heavy overclocking though ;)
Now cooling both CPU and GPU is going to be pricey, GPU waterblocks run around $150 CND, cpu waterblocks around $60-$70 or so, plus your rad will be atleast $50 for a dual which is going to be BARE minimum for this build, you also need tubing that matches all your fittings, barbs and fittings for every connection more then likely, a decent pump runs around $75, you can get fans pretty cheap if you grab some yate loons though. Personally I dont see much reason for watercooling this rig unless you plan to overclock your videocard and CPU heavily, otherwise its going to do perfectly fine on air, ive seen 9550s OCed to 4ghz on air plenty...
The Builders Hammer
  #22 (permalink)
Old June 11, 2009, 04:26 PM
Prof. Dr. Silver's Avatar
Originally Posted by Beermaster View Post
Well hardware order is in WEWT!!!!
Dude! What did you order, besides a few beers?
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
  #23 (permalink)
Old June 11, 2009, 07:46 PM
Beermaster's Avatar
basicly i ordered what you suggested lol
changed up the SSD for the Gskill 64Gb, didnt get the power supply, as i have a Cosair 650w already, or if i want to get fancy i still have the tagan 1100w power supply i won from here :)
still researching the water cooling, as for budget i still have over 1k left hehe
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov Acer One*8gb SSD*WinXP pro
Tathar WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
  #24 (permalink)
Old June 16, 2009, 07:59 PM
Beermaster's Avatar
okay parts are starting to trickle in, now i was torn on the case, but after talking to a few different people, i have desided on the Cosmos S
Now going to pick up the case tommorow strip it down, and take to the powder coaters, but dont know what colour to get done!!!
Got to strip it down to see what i can get powder coated, the interior is going black of course :D
  #25 (permalink)
Old June 16, 2009, 08:08 PM
This is going to be one sick build! Make sure we get PICS!
  #26 (permalink)
Old June 16, 2009, 08:14 PM
Beermaster's Avatar
i am really hoping so :Dm never done a build quite like this, so really looking forward to it
and yea got a nice new camera for xmas that will be working over time on this build :D
  #27 (permalink)
Old June 17, 2009, 09:11 AM
Beermaster's Avatar
:help:Okay having a delima with myself about watercooling
Just pricing out the setup, has scared me a little, didint relize how much it was going to cost, i had a budget in mind (so did the ball and chain) and well this has surpassed her budget.
here is the list as it sits now
1x EK-ANTI-CyclonEK-ANTI-Cyclon
1x TFC Xchanger - High Performance Triple Radiator 360
1x EK-D5 X-TOP - Acetal G1/4 Rev.2EK-D5 X-TOP - Acetal G1/4 Rev.2
1x Swiftech MCP 655-01 Water Pump with speed controller
1x EK-Multioption RES 150EK-Multioption RES 150
3x GELID Wing 12 1500 RPM UV Green 120MM 64.3CFM
2x K - Coolant Fill Port / Drain ValveK - Coolant Fill Port / Drain Valve
6x TFC - High Flow Fitting G1/4" - 3/8"ID - 1/2"OD 45 Rotary
4x TFC - High Flow Fitting G1/4" - 3/8"ID - 1/2"OD with O-Ring
10' Feser Tube UV Hose - 3/8" ID - 1/2" OD - ACID GREEN (1')
1x Feser One - Cooling Fluid - UV ACID GREEN
1x EK-Supreme-PlexiEK-Supreme-Plexi
1x EK Supreme Backplate CPU LGA755
now i feel bad as well, cause i had some really great help with this list, he spent a couple hours with me explaining everything and making sure i got what i was looking for in my mind.
I just don't know what to do
Here is the rest of the build for a FYI
CPU: Intel Q9550
Mobo: GA-EP45-UD3P
GPU: GeForce GTX 275
Ram: OCZ Reaper 4Gb PC-8500 x2
SSD: OCZ Vertex 120Gb
HDD fWD 1Tb WD1001FALS Caviar Black
Case: Coolermaster Cosmos S
  #28 (permalink)
Old June 18, 2009, 12:24 PM
Beermaster's Avatar
So are those parts okay? have i missed anything, or have i gone a bit overboard?
  #29 (permalink)
Old June 18, 2009, 12:31 PM
You gotta wait for the H2O guru's the show up man.... I have no clue here! :)
  #30 (permalink)
Old June 24, 2009, 07:02 PM
Beermaster's Avatar
Okay got all the computer parts (except the watercooling, still waiting) But I FORGOT SOMETHING grrrrrr
I though i had a 1000w power supply here, but looks like i might have sold it awhile ago, damn...
I have a HX520w is that going to be enough, or do i need to run out a grab a 750/850? (dont really want to if i don't HAVE to)
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
