Old June 11, 2009, 07:49 AM
Prof. Dr. Silver's Avatar
"You can only rebuild every three years...."
She never said ANYTHING over upgrading did she???? LOL
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old June 11, 2009, 07:58 AM
Beermaster's Avatar
ohhhh sneaky lol, i still think i would get caught on that lol!!
I have always said, it is easier to beg for forgiveness, then to ask for permission
But that has back fired on me a couple times lol (never come home with a new 2009 Mustang Conv, and go "honey look what i just bought!!!" ... that ended badly)
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov Acer One*8gb SSD*WinXP pro
Tathar WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old June 11, 2009, 08:06 AM
Hahahaha, I'm about to put myself through the same situation. I'm going to get that Q9550 myself!
Anyways, you'll have to ask other people about the H2O part cause I am clueless when it comes to that..... but you have quite a few bucks to play with so I don't think that will be an issue!
Old June 11, 2009, 09:11 AM
martin_metal_88's Avatar
+1 Prof.Dr.Silver, Realy good build with realy great part, The only thing I change is to go to G.skill, Mushkin or Corsair memory over OCZ, better quality and compatibility. With that build you are ready to run every single game a ultra high. If I can with a 4870 a GTX 275 will be abble to do as well.
Ask for more
Old June 11, 2009, 09:17 AM
Ask for more
Yeah, you can basically pick any manufacturer over OCZ, I just picked it because it was the first one I saw.... it's decent and I've had very little issues with OCZ. I picked nVidia over AMD/ATI due to it's rendering/CUDA skills :)
Old June 11, 2009, 09:34 AM
Beermaster's Avatar
Is the OCZ really that bad? I have always heard good things about it, damn thats too bad, i really liked the looks of that reaper memory lol
Okay off to ncix to find new memory to add to the list :D :D
What about these Gskill
Old June 11, 2009, 09:49 AM
Beermaster's Avatar
Okay all those parts are now ready to order, now lets get down to the Watercooling parts for this beast
oh the Case i am using is Cooler master Mystique 632
Old June 11, 2009, 10:25 AM
So for watercooling what are you looking to cool, CPU, CPU+ GPU, maybe the chipsets as well? NCIX is a good place to order from. Also AFAIK that case doesn't have spots for internal rads (I could be wrong) but you may want to consider that or using a radbox.
  #19 (permalink)
Old June 11, 2009, 10:40 AM
Beermaster's Avatar
Your right, i have to mount the rad externally, i just figured i didnt have to drop a couple hundrend bux on a new case, when this one should work fine.
I would like to go the full CPU and GPU. i am not planning (keyword here) on OC'ing this machine
  #20 (permalink)
Old June 11, 2009, 01:23 PM
Beermaster's Avatar
Well hardware order is in WEWT!!!!
Still researching the watercooling parts
What is the CoolIT systems?
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
