Old June 9, 2009, 12:03 PM
Default $5000 build
i7 975
evga x58 classified
ocz 14400 reaper 6 gb
EDIT: going with 2 GTX 285 in SLI now
2 150gb velociraptor in raid 0
EDIT: corsair 1000W PSU
cosmo s
watercooling
does this look good?
thanks for looking
Old June 9, 2009, 12:12 PM
bojangles's Avatar
Go with 3 GTX285s. You'll only need a 1000W PSU. Case is really up to you, just make sure it has decent airflow for all those parts. I assume you're WCing the GPUs as well?
Old June 9, 2009, 12:14 PM
Soultribunal's Avatar
Well, if you are at the point of Using $5000 to build a new Computer. I'll make a few suggestions.
WD Black 640's in Raid 0 will basically give you a Raptor Raid array at a fraction of the price.
OCZ RAM? Hmmmm for your Caliber of Build Go with either the latest Mushkin Offering or Dominator GT RAM.
Much better quality in my opinion at least.
A 975 i7? Do you mean 965 perhaps?
If thats the case (considering Intels website is listing the 965 as their highest), get the 920 and save yourself a Small Fortune and OC the hell out of it. After all , you are listing WC'ing your Rig, Most people only do that when they are pushing their Rigs to the Limit.
My thoughts at least,
ST
www.realhardwarereviews.com
Old June 9, 2009, 12:17 PM
On another Note, that 1500W PSU will only ever give you 1200W From the wall unless you get a Specific 20A Plug Outlet Installed in your House.
So, Opt for something more along the lines of an Enermax Revolution 1050W.
Regards,
ST
Old June 9, 2009, 12:24 PM
id do... for that ammount
3x EVGA GTX 285 2GB FTW
EVGA 9800GT 512mb for Physics
EVGA x58 Classified w/ NF200 Chip
i7 975 Extreme Edition
Silvertone TJ07 w/ Coolit Boreas
Pioneer Blu Ray Burner
Pioneer DVD Multi Burner
6gb Corsair Dominator GT 7-8-7-20 2000MHZ
x-fi forte sound card
pc power and cooling turbo cool 1200w
2x 32GB Intel x25-e raid 0
2x 1TB WD black 1tb raid 1
Old June 9, 2009, 12:46 PM
Chos3n's Avatar
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
Old June 9, 2009, 12:55 PM
Originally Posted by Chos3n View Post
Old June 9, 2009, 01:08 PM
MpG's Avatar
MpG MpG is offline
@OP: Can you give some details regarding what exactly you want for this rig to do? Your component choices are all over the place, to put it mildly. You've got downsized HDD's, when the price difference between them and 300GB versions is pretty minimal, you're listing older GTX280's, and what I think most would consider mid-grade memory sticks. Yet you're also listing a high-powered motherboard, PSU, and processor, and THREE GPU's. We could probably give some better suggestions if you knew what your goals were.
Old June 9, 2009, 01:19 PM
3.0charlie's Avatar
The Cosmos S will not allow 3 dual slot GPUS to be installed. It only has 7 rear slots.
Hydro-Quebec is salivating...
Old June 9, 2009, 01:22 PM
MpG's Avatar
MpG MpG is offline
Don't quite follow that reasoning. Three dual-slot GPU's = 6 slots occupied. Or am I missing something?
AMD 5000 BE on my Gigabyte GA-MA790FX nige Overclocking, Tweaking and Benchmarking 1 February 9, 2009 10:12 AM
5000+ BE or regular 6000+ Scart CPU's and Motherboards 4 September 17, 2008 10:20 PM
Watercooling an AMD Athlon 5000+ BE BALISTX Water Cooling 14 July 20, 2008 01:00 PM
Lg 226wtq 5000:1 ! Babrbarossa Display Units 6 October 13, 2007 10:54 AM
