Old May 30, 2009, 06:26 PM
Dashock's Avatar
Default Help Computer turns on then shuts off in 3 seconds
Alright basically i moved components to a new case and everything was working fine my cuz plugged in a sd reader into the usb slot it said unknown device and then he plugged in a sandisk cruzer on the same slot and then the computer froze. I then proceeded to restart and now i can only turn on the power for 3 seconds all the fans work and then it shuts of..
I have tried to single out components like videocard,ram,hard drive so i know its not that.
thanx all.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old May 30, 2009, 06:32 PM
geokilla's Avatar
Clear CMOS?
Oh I remember I was playing with my friend's brand new Antec 900 computer before, then I took out the USB cus earlier he was transferring some files over to my USB. The funny thing was, the USB slot got stuck or something, so the computer wouldn't turn on. I don't know how he fixed it, but I believe he said something about pulling that USB slot out. Basically, the USB slot was broken.
Old May 30, 2009, 06:42 PM
Dashock's Avatar
i have already disconnected the usb connection ot the motherboard its really strange occurance.
Asus P5Q-E
Corsair Cx600M
Old May 30, 2009, 06:51 PM
CMetaphor's Avatar
Quadfather
Definitely try to reset the cmos by pulling out the cmos battery for a minute. If that doesn't work, disconnect everything possible and strip the system down to the basics (1 stick of ram, lowest-end video card you have, PS2 keyboard? and nothing else). Tell us how that goes...
Old May 30, 2009, 07:04 PM
Dashock's Avatar
i reset the battery and cleared cmos still doing it, if one of the components on the motherboard or capcitors fried would the motherboard green light still come on ???
Asus P5Q-E
Corsair Cx600M
Old May 30, 2009, 07:08 PM
Arinoth's Avatar
I had this problem, you may want to check/look at your PSU, because for me, half the caps had blown.
Old May 30, 2009, 07:10 PM
CMetaphor's Avatar
Quadfather
Sorry to say it Dashock, but if a USB port was indeed shorted it could mean a dead Mobo then.... condolences. Can you RMA?
Old May 30, 2009, 07:14 PM
Dashock's Avatar
How would i check if the caps are blown... and Metaphor if the mobo was fried then wouldnt the green light at the bottom not work ??
Asus P5Q-E
Corsair Cx600M
Old May 30, 2009, 07:22 PM
Arinoth's Avatar
Well look at both your mobo and there should be a little window into your PSU either in the back or at the bottom, if there is anythign "oozing" or really anything on any of the caps that doesn't look like it should be there, like the cap has opened, then its a blown cap
Old May 30, 2009, 07:35 PM
CMetaphor's Avatar
Quadfather
Yes, it's not only possible, it's depressing. I've tried to "resurrect" many dual-socket boards at work that would still have their standby LED green to no avail... Sorry dude...
LCD Monitor Turns On For A Few Seconds Then Goes Black 300 Troubleshooting 0 January 9, 2009 07:58 PM
My Screen Turns white CORE Troubleshooting 0 December 30, 2008 11:49 AM
14 seconds to boot Scart CPU's and Motherboards 16 April 13, 2008 05:22 AM
laptop shuts off during gaming? t0m Mobile Computing 9 February 18, 2008 01:34 AM
This forum requires that you wait 5 seconds between posts.. Deathspawner Suggestions & Feedback 19 March 22, 2007 01:10 PM
