Old May 29, 2009, 01:26 PM
somecanadianguy's Avatar
Default Help suggest a build for a friend...
This is what he wants...
Maingear Ephex (Intel Core i7 965) Desktop reviews - CNET Reviews
Can you help me help him save a bit of money?
Old May 29, 2009, 01:36 PM
SugarJ's Avatar
I'd bet you could build a wc'ed version without the fancy paint job for probably $5k. Let me work on it.
Reference ID:1026421670 Del Item Description In Stock Part # QTY Price Ext. Price Silverstone Temjin TJ07B-W Black E-ATX Aluminum Case 7X5.25 6X3.5INT No PS W/ Window
Usually ships in 1-2 business days. In Stock 20019 $400.25 $400.25 EVGA X58 Classified EATX LGA1366 DDR3 4PCIE-16 1PCI SLI SATA2 eSATA Dual GBLAN 1394 Motherboard
In Stock 38253 $459.99 $459.99 Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
Usually ships in 1-2 business days. NCIX.com SURPRISE SPECIALS!
Available in limited quantities only, with a limit of 2 per customer. Hurry! No rainchecks or Price Matches for these items are available after limited quantities are sold out. Note: Your order for these items are counted only after you've completed your purchase.
In Stock 31000 $96.99 $193.98 Corsair XMS3 Dominator TR3X6G1600C8D 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24 Core i7 Memory Kit
In Stock 34802 $199.99 $399.98 Intel X25-M 80GB 2.5IN SATA2 NCQ Solid State Disk Flash Drive SSD
Usually ships in 1-2 business days. In Stock 33277 $419.45 $419.45 EVGA GeForce GTX 275 Superclocked 648MHZ 896MB 2.376GHZ DDR3 PCI-E Dual DVI-I HDTV Ou *IR-$20*
FREE EXPRESS SHIPPING FOR THIS ITEM!
Usually ships in 1-2 business days. In Stock 37775 $279.99 $839.97 LG BH08-LS20 Black BLU-RAY Writer 8X BD-R 16X DVD-R SATA Lightscribe Internal Drive
In Stock 36858 $228.98 $228.98 LG GH22LS30 Black 22X SATA Lightscribe DVDRW OEM
In Stock 31940 $30.99 $30.99 Intel Core i7 Extreme 965 Quad Core Processor LGA1366 3.2GHZ Bloomfield 8MB LGA1366 6.4GT/S
Usually ships in 1-2 business days. In Stock 34600 $1,279.99 $1,279.99 Silverstone Strider ST1200 1200W ATX EPS12V 94A 12V Modular Power Supply Black 135MM Fan 80PLUS
Usually ships in 1-2 business days. In Stock 28822 $337.56 $337.56 Shipping Estimate: Postal Code:
Save time and money by letting one of our experts assemble and test your new custom PC. Choose from a wide range of components without having to worry about the headaches of troubleshooting incompatible hardware. We will install the Windows® operating system of your choice(if purchased in the same order) and all necessary drivers, as well as perform a complete compatibility check. Before shipping, your system will be given a final inspection including cable optimization to ensure proper airflow and safety during shipping. Add Item Description
In Stock
Part #
Price
PC Assembly and Testing with 1 Year Limited NCIX System Warranty (PRE-CONFIG OS If Purchased) Yes 7842 $50.00 Assembly options are non-refundable. Please ensure your shopping cart contains all necessary items to build your custom PC.
If you require any assistance choosing your components, please contact the PC Advisor at PC@ncix.com.
Check to delete an item YOUR TOTAL $4,591.14
OK, so $4600, no pricematching done, without Vista, or mouse and keyboard. And a CPU WC loop could be done for about $300. That's a little cheaper than the $8700 in the article. I went with 3x GTX275 SCs, because that would be about equal to the 280's.
Old May 29, 2009, 01:56 PM
I don't know if he'll want to deal with water...
Old May 29, 2009, 02:00 PM
SugarJ's Avatar
So throw a TRUE and 2 good fans on it. $100.
Edit: and go to a TJ-09 case, better air flow, less money. Saves about $75.
Old May 29, 2009, 02:03 PM
joeperson's Avatar
Another reason you can point to when you tell him he's and idiot to want an $8000+ machine.
There are some lower quality all in one solutions that might help avoid dealing with water but still leave him with a "water" cooling setup though.
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Old May 29, 2009, 02:06 PM
Maybe I'm just over-tired, but... Huh??
Old May 29, 2009, 02:08 PM
Is a 965 chip really worth the $1200.
SugarJ's Avatar
Or go with the Boreas edition Silverstone from Cool-it. Selfcontained TEC cooler.
Old May 29, 2009, 02:09 PM
SugarJ's Avatar
Not in my books. That system showed it at 3.97 GHZ, you should get a D0 920 to that easily under water.
Old May 29, 2009, 02:10 PM
I suggested a 920, but he's not sure about OC'ing...
Build for a friend lanken123 New Builds 5 May 6, 2009 08:54 PM
Build for a sick friend Lpfan4ever New Builds 53 January 26, 2009 06:46 PM
Suggest RAM / HDD / Cooling to finish my UnDELLify build? frontier204 New Builds 2 December 21, 2008 09:30 AM
Please suggest me parts for a new budget build. NoobLordSpud New Builds 21 July 13, 2008 09:49 AM
Build 4 a Friend. BALISTX New Builds 5 June 25, 2008 01:21 PM
