Old May 29, 2009, 08:11 AM
Default Hooking Up New Build: Need Help
Hi guys,
I'm connecting my new computer and ran into a bit of a snag with my monitor. The plug on my monitor is 15 pin, but on the back panel of my tower there is no matching socket. Instead there is a socket with 28 pins, 4 on the far left and 3 rows of 8 on the right hand side. If anyone can point me in the right direction it would be much appreciated, thanks!
Old May 29, 2009, 08:30 AM
Soultribunal's Avatar
That would be a DVI connector on the back.
What you need (if you have a PCI-e VC it should have come with it) is a DVI to VGA Adaptor in order to hook it up.
Regards,
ST
www.realhardwarereviews.com
Old May 29, 2009, 09:21 AM
Regards,
ST
Thanks very much. Low and behold the adapter was in video card box .
Old May 29, 2009, 09:25 AM
NP, I knew exactally what it was when you said it lol :)
I did the whole WTF thing myself first Time I got a VC with just two of those loL!
Regards,
ST
hooking up a "studio"? Cadence Audio 14 March 16, 2009 09:03 AM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
